  New Posts New Posts RSS Feed - Bushings for REAR sway bar ref D2OZ-5B486-B
ViperGTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ViperGTS Quote  Post ReplyReply Direct Link To This Post Topic: Bushings for REAR sway bar ref D2OZ-5B486-B
    Posted: 14-November-2013 at 10:33AM
Bushings for REAR sway bar ref D2OZ-5B486-B (Torino 73/76 or Tbird 1973 or LTD 77)
I'm actually working on a 1978 Kellison Stallion.
The Ford rear sway bar is the same on Torino 73/76 or Tbird 73 or LTD 77
and the bushings that goes into the eye on the end of the REAR sway bar ref D2OZ-5B486-B is something impossible to find.
It's possible to replace them with small modification (cut the length and use a
little bigger axe) with this one : 77 04 001 371 for Renault.
I know that Renault bushings are something rare at the US, but :
The bushing Renault was using on R12/R15/R17 AND DACIA
Analogous \ Similar Parts of RENAULT 7704001371
A.B.S       270293
MALO     277
MOOG    RE-SB-1332
RTS     017-00402
You can try  RESB1332 on www.rockauto.com
Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-November-2013 at 4:28PM
what i used for my 74 gran torino factory rear sway bar bushings in urethane was energy suspension # 8141r in the sway bar eye, and for the link to frame bracket was energy suspension # 8101r
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2013 at 3:10AM
John,
Looking thru the Energy Suspension catalog, I'm going to assume there is a "9-" in front of those part numbers (universal application)? What part number did you use for the actual sway bar bushing? My rear bar measures about .687" od...
Thanks!
[IMG]TO BE RELOADED[IMG]
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2013 at 5:07AM
joe, yes there was a "9"  my bad the part #'s are   energy suspension 9-8141 universal shock bushings (for sway bar)    energy suspension 9-8101 universal shock tower grommets (for sway bar  link to frame bracket)      for the sway bar mount on the differential i used prothane # 19-1116  Thumbs Up
energy suspension:
9-8141r (red)
9-8141g (black)
9-8101r (red)
9-8101g (black)
prothane:
19-1116 (red)
19-1116bl (black)
Edited by californiajohnny - 08-February-2015 at 3:11PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 14-August-2014 at 2:30AM
John,
Can you post a few pics showing these bushings installed/mocked up? Won't be long until I'll begin reassembly of the rear end and would like to have all my ducks in a row....
THANKS
Post Options Post Options   Thanks (2) Thanks(2)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-August-2014 at 2:38AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 14-August-2014 at 5:19AM
THANKS JOHN
1973torino429 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973torino429 Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 1:53AM
John, I bought the urethane pieces that were recommended and have misplaced the outer and inner sleeves, any other options???
1973 Gran Torino 429
1973 Gran Torino 351 4V
1972 Gran Torino 351 CJ
1972 Mach 1 351 CJ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 4:23AM
IDK... maybe try to find a piece of metal tubing the correct size.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 5:33AM
what size are the bolts?
front sway bar link kits come with a generous stub of sleeve ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 6:35AM
yes the inner sleeve shouldn't be an issue to find but i think he's more concerned with the outer shell that's pressed into the bar....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 6:56AM
Originally posted by 1973torino429 1973torino429 wrote:
John, I ... have misplaced the outer and inner sleeves, any other options???
yeah that's gonna be tough
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973torino429 Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2017 at 2:27PM
Yeah, I have the inner sleeve issue taken care of, the outer is gonna be the problem , emt pipe is close but not good enough, I'll figure something out....
1972 Mach 1 351 CJ
