Forum Home Forum Home > General Discussion > How-To Articles
  New Posts New Posts RSS Feed - bypass 74 seatbelt interlock
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Topic: bypass 74 seatbelt interlock
    Posted: 24-September-2017 at 2:25PM
ok i did this mod on my 74 and i've been asked about it since then...memory not so great lately (getting oldConfused) but it was 4 years ago when i did this...
ok to bypass the interlock box up above the glove box (and it can be removed as it is now dead)
at the connector, locate the lower left 2 wires--red with a blue stripe, and the double wires --white with purple dots... cut them strip them back and connect them together--2 white ones can stay side by side twisted together and connect them with the red/blue wire
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2017 at 2:31PM
you can now remove that big interlock box as well as the reset box on the RH fenderwell just leave the connectors as they are no longer needed Wink
