  New Posts New Posts RSS Feed - C-6 Transmission cooler lines path
grandpops4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Topic: C-6 Transmission cooler lines path
    Posted: 14-October-2018 at 7:08AM
Hi all, can someone tell or show me in pictures how the transmission cooler lines hook up on a 1973 Gran Torino 429 with a C-6 transmission. The radiator connections are on the drivers side and the transmission connections are on the passenger side. Thanks and God Bless. Grandpops4
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2018 at 9:14AM
they cross from side to side in front of the oil pan
part number in ad is correct for 72+, listing text states 70-71 for some reason
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2018 at 11:34AM
Port routing goes like this: C6-front "output" port is routed to upper radiator trans cooler fitting. The trans cooler's lower port goes to rear "input" port of C6. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2018 at 11:53AM
Thanks for you responce but what I need is where the lines go. Do they go aling side the engine or where do they go. If I can get a diagram that would be great.
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2018 at 6:28PM
they go along the engine near the oil pan on the passenger side and had a mounting strap to the crossmember near the motormount then cross over in front of the pan near the harmonic balancer then go to the drivers side radiator tank, if that helps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2018 at 2:45AM
Yes thanks
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote grandpops4 Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2018 at 1:11AM
Do the lines go below the motor mount and above the suspension or above the motor mount. Thanks
gm
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2018 at 4:24AM
if i'm understanding your question... they basically lay on the top of the cross member between the inside of the motor mount and the oil pan, straight below the pan bolts
