californiajohnny's other cars |
Post Reply | Page <1 23456 8> |
stanman
I think what you were trying to say is as you get older it's harder to get in and out of a two door. You are no spring chicken anymore mister. |
unlovedford
Not a spring chicken, but not an old Rooster, either.
speaking of "getting old" ^^^ i may have to remove the side bars from my 6 point stainless roll cage in my monza some day when i drive it again now it would probably take me 10 minutes to get in or out for years i always joked about "yeah right, when i get old and fat, haha NOT ME!" ( not quite so funny as it used to be )
unlovedford
LOL, nope. I heard myself "OOF" when I got into the Civic to move it the other day. Later, I made the "Arrugh" sound when I hoisted myself up into the F150 4X4. Sheesh.
stanman
Hate to say I told you so but.....
stanman
Love driving my old Celica until I have to get out of it. Not fun.
MrSmog
yea I used to drive from frederick md to naples fl in one straight shot, just stop for gas, coffee and to pee. Now after about 200 miles the knees hurt, hips hurt, back is always killin me. gettin old is so much fun lol |
Getting old is why I don't drive my T-Bird as much as I used to. When you are as tall as I am, getting into a car that low (comparatively) is a bit of a pain. Easier to hop in the truck. (Even if it IS a GMC)
today doing some necessary upgrades to my S-10 blazer...heavy duty tubular upper control arms poly bushings, upper ball joints! just did lower ball joints, new CV axles, new hubs, and idler arm, about a month ago. still need to replace the pitman arm (looks like i'll have to pull the whole box to get the arm off and i got new poly bushings for the lower control arms and sway bar and i have new poly bushings for the rear on the way
check out all that tire space! "THIS AIN"T YOUR GRAMPA"S S-10 SON! " |
i got the lower bushings and the swaybar bushings changed the other night. just did the pitman arm what a PITA! i did have to remove or at least tried to remove the steering box (pressure hose rusted to the swivel nut and with my hidden 9,000# winch in the way, no way to get the box out) so i was able to tilt it just enough to impact the nut off and get the puller on it, pitman arm DONE but getting the box back into the steering shaft splines and into position, that's another story about 2 hours total of screwing around to do a 10 minute job ( on most other vehicles) oh, and did i mention... the steering shaft is only 1/8" from the front header tube. but with the 3" body lift, it sure makes stuff along the frame easier to work on
fordpower
Wait till you are in your 70's and have to get the wife to open the damn safety cap on your meds.
This is why we have children! To OPEN the damn childproof caps. |
ok, got most of the rear spring poly bushings in, that damn deicer rusted some of the bolts solid the front spring bushings are staying rubber for now since the bolts won't come loose i shattered a 1/2" drive extension, bolt didn't budge! so i'll soak it with PB blaster throughout the summer and try again later
part of my new 1 ton idler arm came today, waiting on the other piece, then i'll fab up my own adapter bracket ^^^ since this one pictured is $200
this will cure the constant replacing of stock idler arms |
Brace for the bottom of the idler arm shaft?
http://www.zr2usa.com/mboard/index.php?showtopic=53436 |
On my old F150, I had a plate with a bearing supporting the bottom of the pitman arm shaft. Got tired of the annual steering box replacement.
got the 1 ton idler arm conversion finished! spent about an hour last night fabbing up my own bracket and about another hour doing several mock up's and bolting and welding it to the frame
i shouldn't never need to replace this set up, that arm and pivot is a BRUTE! all the upgrades finished ready to go "wheelin" so who needs parts from that yard |
well while getting parts at that yard today, i found an older blazer with a good RH power window motor (i've been looking for one for the last few years) he charged me pretty good for it
but i was installing it, removed my window to tint it, got all done with the tint put it back in and was holding it up to attach the regulator to it and BOOM the f**king window exploded!!! i guess i tightened the bolts that go through the glass a little too tight i think i have a spare window out back in a parts truck? but now i'll have to order and wait for that pre cut tint no sense putting it all back together just to take it back apart later UNBELIEVABLE!!! |
MrSmog
sounds like a good time for a tall cold frosty one
well after some internet research for part interchangeability i came to the conclusion that the trucks and blazers were different, but i thought all the doors were the same? but tonight i measured the parts truck it appeared to be the same...so i pulled the glass from it and checked it in my door...they are exactly the same !!just as i thought at least i don't have to buy another window it hasn't even been 24 hours and a big damn spider had claimed the inside of my blazer ( i promptly evicted him ) |
unlovedford
Dang! Sorry about the window. Lucky you have an extra!
GTW
Senior Member Joined: 21-January-2012 Location: SC Status: Offline Points: 5784 |
Our '91 S10 Blazer's front passenger window motor just quit working too...but luckily we have a '93 S10 4x4 extended cab truck for parts.
1973 Gran Torino station wagon 1972 Gran Torino 4 Door 1971 Maverick 2 Door |
Far as I know the trucks didn't get power windows until the body change in 94 and the early blazers 83-86? Were manual.
I'll check the driver side motor I seem to remember it was different and better it came out of a 87. The ones used in 89 to 93 seem to be not as good IMO the contacts melt in the plastic causing a bad connection |
unlovedford
I've had a few 1st gen S-10's with power windows. Liked them, favorites were extended cabs and Stranger. We still occasionally talk about that little truck and how good it was. Best Chevrolet I ever owned (probably because of the Ford in it).
what???
unlovedford
Half Chevrolet S-10 and half Ford Ranger, hence the name Stranger. One of a kind truck with the heart of a lion.
GTW
Nope it's got power windows. Tahoe trim level...though the interior is quite a bit more ransacked now.
Edited by GTW - 07-September-2016 at 3:46PM |
GTW
Any pictures of Stranger, Joe? I think I remember one but it looks to be long gone.
yeah my 90 is a Tahoe just like that except with the digital dash
