  New Posts New Posts RSS Feed - Can someone help me?
Dgeek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgeek Quote  Post ReplyReply Direct Link To This Post Topic: Can someone help me?
    Posted: 19-October-2018 at 6:58PM
I have a 72 GTS, Q code that I am restoring. While doing some bodywork I came across 4 dimes that were secured in the door jambs and on the ends of the doors. Has anyone ever heard of or seen this before?
Any help would be greatly appreciated.
Thanks!
Danno
FORDMUSCLE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FORDMUSCLE Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2018 at 12:01AM
Your car had side moldings and someone epoxy glued dimes in from the back to fill the holes...I've done it before....quick fix if u don't want to weld...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-October-2018 at 4:48AM
i've never seen it done that way with dimes before but yeah they used them to cover the molding holes
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2018 at 7:04AM
Manufacturing error.
Those are supposed to be installed on the brakes.
Makes the car stop on a dime.
(Boo!!! Hisss!!!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2018 at 2:35PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 18-December-2018 at 4:44AM
(Boo!!! Hisss!!!)
https://www.youtube.com/watch?v=gpaOy8b8X6A
I guess there are many questionable ways to do bodywork. Ouch
Edited by gpd294 - 18-December-2018 at 4:44AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2018 at 2:13PM
i have clamped pennies behind holes when using a mig welder to fill them...
but they don't stay/stick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2018 at 3:13PM
i was going to mention that... but pre 1985 pennies!!! were solid copper (not after that)
but best thing to do is grab a copper welding spoon for $10 at harbor freight Wink
picon3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2018 at 6:32AM
Being a numismatist, I thought I'd drop this in here Wink Paul~
If your Lincoln Memorial penny has a date before 1982, it is made of 95% copper. If the date is 1983 or later, it is made of 97.5% zinc and plated with a thin copper coating.
1972 GTS 351CJ-4V black/black
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2018 at 7:06AM
Wheat leaf pennies are all copper, no?
Post Options Post Options   Thanks (1) Thanks(1)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2018 at 7:28AM
Found this handy table on Wiki.  Wheat Pennies minted from 1909 to 1958.  Paul~Smile
1793–1795~100% copper208 grains13.48
1795–1857~100% copper168 grains10.89
1856–186488% copper, 12% nickel (also known as NS-12)72 grains4.67
1864–1942bronze (95% copper, 5% tin and zinc)48 grains3.11
1943zinc-coated steel (also known as 1943 steel cent)42 grains2.72
1944–1946brass (shell case copper) (95% copper, 5% zinc)48 grains3.11
1947–1962bronze (95% copper, 5% tin and zinc)48 grains3.11
1962–1981brass (95% copper, 5% zinc)48 grains3.11
1982[7]brass (95% copper, 5% zinc)48 grains3.11
copper-plated zinc (97.5% zinc, 2.5% copper)38.6 grains2.5
1983–presentcopper-plated zinc (97.5% zinc, 2.5% copper)38.6 grains2.5
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2018 at 12:00PM
paul, you may be correct, i thought it was 85 (memory sucks getting older Confused)
This page was generated in 0.143 seconds.
