CANT START |
pakman
New Member Joined: 22-April-2019 Location: Wisconsin Status: Offline Points: 2 |
Posted: 22-April-2019 at 4:20PM |
added pertronix coil and distributor with a relay
replaced damper prior to that install. won't start. replaced carb with new identical Edelbrock 600 cfm still NO start. replace fuel filter. still NO start. will be replacing plugs is next step.. what should my TDC initial advance be on dampener??? also ordered piston stop to verify TDC.... got anything for me would be great.. can't sleep at night. mind races to fast maybe need. Something for that too.
timing should be about 8-10 degrees before top dead center possibly a little more depending... but 8 to 10 should get you started then tune from there...
do you have fuel squirting down the carb when you move the throttle? and do you have any spark? |
I am assuming it ran fine before you swapped the Pertronix. What is the year, make, model and engine is it?
I'd check for spark first and make sure your Pertronix is getting power in both start and run.
