  New Posts New Posts RSS Feed - car dies when put in drive
Readaniel18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Readaniel18 Quote  Post ReplyReply Direct Link To This Post Topic: car dies when put in drive
    Posted: 03-November-2018 at 1:37PM
I have a '73 Gran Torino Sport and just recently I've started having a lot of backfire and also when put in drive or reverse it dies. I've already taken the carb off and rebuilt it, change the spark plugs checked all vacuum lines and checked the timing and everything checks out. wondering if anyone has had a similar issue, and if so what fixed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 2:55PM
How is the timing? How many miles on the engine? Factory timing chain?
If the timing is off the scale it may have jumped a tooth.
Edited by handsofstone - 03-November-2018 at 2:56PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Readaniel18 Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 3:19PM
Timing just got done a few weeks ago, was the first thing I checked. Yes factory timing chain. 32,000 miles
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2018 at 4:49PM
could be the timing chain? also check for a major vacuum leak!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 1:44AM
If timing chain checks out(may be able to see/check through fuel pump hole) could be that the carburetor is too lean(a small piece of debris in one of the small internal orifices), also check the ignition coil and/or it's wiring(could be wired "bass-ackwards").
Edited by aquartlow - 04-November-2018 at 1:45AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 2:27AM
What engine and carb do you have?  Is it backfiring through the carb or through the exhaust?  Was there any problems before you rebuilt the carb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 5:47AM
points in the distributor? if so that's a 99%er
and if the original nylon cam sprocket is still in there, times up
faster way to check the chain is to turn the crank backwards and watch how many degrees it takes for the rotor to move. not quite as accurate but non-invasive
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 6:11AM
are you running points? double check the firing order on the plug wires too
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2018 at 9:15AM
Pcv valve is something to look at as well.
kevinj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinj Quote  Post ReplyReply Direct Link To This Post Posted: 30-November-2018 at 11:15AM
I had similar problems w different older vehicles----if the problem recently started could it be contaminated fuel ?  have you checked the point and plug gap ? , another thought is the brake booster needing replaced- internal diaphragm old and falling apart?  sucking too much air- clamp it off w vise grips and see if it makes a difference-
