car dies when put in drive |
Readaniel18
New Member Joined: 04-April-2018 Location: Hawaii Status: Offline Points: 3 |
Posted: 03-November-2018 at 1:37PM |
I have a '73 Gran Torino Sport and just recently I've started having a lot of backfire and also when put in drive or reverse it dies. I've already taken the carb off and rebuilt it, change the spark plugs checked all vacuum lines and checked the timing and everything checks out. wondering if anyone has had a similar issue, and if so what fixed it.
handsofstone
How is the timing? How many miles on the engine? Factory timing chain?
If the timing is off the scale it may have jumped a tooth. Edited by handsofstone - 03-November-2018 at 2:56PM |
Readaniel18
Timing just got done a few weeks ago, was the first thing I checked. Yes factory timing chain. 32,000 miles
could be the timing chain? also check for a major vacuum leak!
aquartlow
If timing chain checks out(may be able to see/check through fuel pump hole) could be that the carburetor is too lean(a small piece of debris in one of the small internal orifices), also check the ignition coil and/or it's wiring(could be wired "bass-ackwards").
Edited by aquartlow - 04-November-2018 at 1:45AM |
What engine and carb do you have? Is it backfiring through the carb or through the exhaust? Was there any problems before you rebuilt the carb?
points in the distributor? if so that's a 99%er and if the original nylon cam sprocket is still in there, times up faster way to check the chain is to turn the crank backwards and watch how many degrees it takes for the rotor to move. not quite as accurate but non-invasive
are you running points? double check the firing order on the plug wires too
handsofstone
Pcv valve is something to look at as well.
kevinj
New Member Joined: 05-October-2013 Location: az Status: Offline Points: 25 |
I had similar problems w different older vehicles----if the problem recently started could it be contaminated fuel ? have you checked the point and plug gap ? , another thought is the brake booster needing replaced- internal diaphragm old and falling apart? sucking too much air- clamp it off w vise grips and see if it makes a difference-
