Car wont start without jump |
JavierV
Member Joined: 15-May-2012 Location: New Mexico Status: Offline Points: 118 |
Posted: 24-June-2012 at 4:02PM |
1972 GTS fastback. When attempting to start vehicle i get a buzzing sound along with "OIL", "ALT" and "BRAKES" lights on but car will not turn over. I did not think it'd be a battery problem seeing as how the lights do not die or flicker. Once i connect with battery cables to my other vehicle i have to let it sit for a minute or two then jump it and it will start and stay on. I drove it for a few minutes and left it running a while longer then turned off and attempted to start again only to run into same problem. Battery, alternator, starter, solenoid, and battery cables are all fairly new (bought within last 6 months/1 yr). Any ideas as to what it may be or have you ran into similar problems?
Mark S.
Senior Member Joined: 22-April-2012 Location: EHT, NJ Status: Offline Points: 374 |
I'm betting you have a bad battery, i.e. defective or some such if it's recent. Try swapping out for a different battery and running it for a while. I've had "new" batteries go bad. If it's only a hot start condition, then you might want to look at the starter.
Mark
1977 Ltd II "Eltee" 1984 Mustang ragtop 2004 Grand Marquis Ultimate Edition 71 Torino GT 429CJ (sold too many years ago to count...) |
NMA
New Member Joined: 18-June-2012 Location: Spencer,Indiana Status: Offline Points: 26 |
I can tell you 99.9% for sure it's your battery. It has enough juice/volts to power idiot lights but not enough amps to turn the starter over. Check your amps with a DMM, also make sure you didn't over tighten the battery cables, I've seen people twist off battery posts inside the battery before.
'55 Buick Special
'74 Mercury Montego MX Brougham '77 Ford F150 |
JavierV
Thanks guys. The battery was indeed weak. But just to be sure i had the alternator and starter tested, both were good. This was the third time having to get the battery charged so i told auto zone i wanted a replacement since i was still under warranty. Also picked up a new voltage regulator to replace the old one.
75GranMan
Is it possible that you have a parasitic draw with your electrical system,causing the weak battery?
