  New Posts New Posts RSS Feed - Carb spacer 4300D.
Carb spacer 4300D.
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: Carb spacer 4300D.
    Posted: 01-December-2019 at 4:55PM
Hi forum...now that I have a nice original 4300D going into my 72 GTS 351CJ, will I need a spacer?
Was there a spacer in the original setup?
Thanks...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 12:03PM
the EGR plate, and mind the worm channel beside the carb pad because there are different ones
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:07PM
Based on the length if the studs I am going to go with yes. My first car in 1980 had one that may have been bakelite or a similar material. You will get the correct answer in a few minutes.
Edited by handsofstone - 02-December-2019 at 2:12PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:09PM
My car has no worm channel. See picture. Will I still need the spacer?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:10PM
Aluminum would be a good spacer as it would help keep the carb cooler which is never a bad thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:11PM
Another picture. Need spacer still? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:18PM
I have the aluminum spacers under my carb. Three of them. Had a detonation issue and now I don't.  Might have been the jet change that fixed it along with timing. If everything lines up without the spacer I would be surprised. The kickdown rod will tell you one way or the other. If it fits correctly without a spacer I would be surprised. We had to bend mine a bit to make it a little longer so it worked as designed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:20PM
Is your car a 4 speed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:23PM
My car is a 4speed/351CJ.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 2:53PM
I have googled many pictures of Torino/Mustang 4300D setups. Some have spacers...some dont.....what was factory?
I bought a Motorcraft 4300D spacer on the ‘Bay. It is about 5mm thick.
All ideas welcome.
Here is a picture of the spacer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 3:41PM
thats the thick base gasket. your studs look short so that should be fine Wink
idk if you can find the correct plastic 1/2" thick solid plastic phenolic spacer with correct longer studs would be good if you have hot "boiling over" issues later Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 3:45PM
the aluminum spacer was normally for the EGR valve which you not have(worm hole trench) that's a good thing!Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 3:52PM
VERy hard to find the correct phenolic spacer....
Is old stock the only way,or does someone sell ‘em?
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 5:28PM
I have never heard of anyone reproducing the '72 spacers. There is a seller that is advertising that he has spacer for sale, but it is a '73 spacer. It has the egr port on it.
https://www.ebay.com/itm/1973-FORD-MUSTANG-AND-MACH-1-351C-4BBL-351CJ-ENGINE-EGR-CARB-SPACER-D3ZE/392516124780?hash=item5b63c8c06c:g:nQQAAOSwA3ddvv-M
Edited by dave302 - 02-December-2019 at 8:04PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 6:19PM
get the carb all rebuilt and put it on with the thick gasket you got and try it... should be fine without any spacer...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 6:25PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 7:31PM
There is another '73 spacer for sale.
https://www.rearcounter.com/D3ZZ-9A589-A-parts439021.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 1:58AM
I will use the thick gasket. Should be good.....
I do not think Ford used those other fancy type spacers......Confused
Awesome!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 2:28AM
Looking your intake manifold's carburetor mounting stud length, I don't believe their long enough to enable a spacer to be used other than the thick carb gasket you pictured above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 8:00AM
1972 had a Ram-Air option so Ford may've ditched the EGR & any spacers for hood clearance?
Anderslober, are the large secondary throttle bores perfectly round or are they an odd egg shape?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 10:03AM
wow...never seen that before! Didnt even check that....will check! It is even difficult to see on my pictures.
IF they are egg shaped......then what?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 10:06AM
that's what DeTomaso did to the stock intake to allow the use of a square flange Holley carb
i just wondered if somebody did the same to yours, hard to see from the pic
all's well carry on!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2019 at 5:15AM
If you are wanting/needing a non-EGR 4300/4350 carburetor spacer, I found this gem in my stash, it came off of a '76 460 out of an E-350 van. Just reply or PM me. It is all aluminum and about 3/4" thick.
