Carb spacer 4300D. |
Anderslober ![]() Member ![]() ![]() Joined: 30-July-2019 Location: Denmark Status: Offline Points: 113 |
![]() ![]() ![]() ![]() ![]() Posted: 01-December-2019 at 4:55PM |
Hi forum...now that I have a nice original 4300D going into my 72 GTS 351CJ, will I need a spacer?
Was there a spacer in the original setup? Thanks...
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 4695 |
the EGR plate, and mind the worm channel beside the carb pad because there are different ones |
handsofstone ![]() Senior Member ![]() ![]() Joined: 13-April-2018 Location: Massachusetts Status: Online Points: 1558 |
Based on the length if the studs I am going to go with yes. My first car in 1980 had one that may have been bakelite or a similar material. You will get the correct answer in a few minutes.
Edited by handsofstone - 02-December-2019 at 2:12PM |
My car has no worm channel. See picture. Will I still need the spacer?
Thanks. ![]() |
Aluminum would be a good spacer as it would help keep the carb cooler which is never a bad thing.
Another picture. Need spacer still? Thanks.
I have the aluminum spacers under my carb. Three of them. Had a detonation issue and now I don't. Might have been the jet change that fixed it along with timing. If everything lines up without the spacer I would be surprised. The kickdown rod will tell you one way or the other. If it fits correctly without a spacer I would be surprised. We had to bend mine a bit to make it a little longer so it worked as designed.
Is your car a 4 speed?
My car is a 4speed/351CJ.....
I have googled many pictures of Torino/Mustang 4300D setups. Some have spacers...some dont.....what was factory?
I bought a Motorcraft 4300D spacer on the ‘Bay. It is about 5mm thick. All ideas welcome. Here is a picture of the spacer. ![]() |
californiajohnny ![]() Senior Member ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Online Points: 11459 |
thats the thick base gasket. your studs look short so that should be fine
![]() idk if you can find the correct plastic 1/2" thick solid plastic phenolic spacer with correct longer studs would be good if you have hot "boiling over" issues later ![]() |
the aluminum spacer was normally for the EGR valve which you not have(worm hole trench) that's a good thing!
VERy hard to find the correct phenolic spacer....
Is old stock the only way,or does someone sell ‘em?
dave302 ![]() Senior Member ![]() Joined: 08-October-2009 Location: usa Status: Offline Points: 3161 |
I have never heard of anyone reproducing the '72 spacers. There is a seller that is advertising that he has spacer for sale, but it is a '73 spacer. It has the egr port on it.
https://www.ebay.com/itm/1973-FORD-MUSTANG-AND-MACH-1-351C-4BBL-351CJ-ENGINE-EGR-CARB-SPACER-D3ZE/392516124780?hash=item5b63c8c06c:g:nQQAAOSwA3ddvv-M Edited by dave302 - 02-December-2019 at 8:04PM |
get the carb all rebuilt and put it on with the thick gasket you got and try it... should be fine without any spacer...
There is another '73 spacer for sale.
https://www.rearcounter.com/D3ZZ-9A589-A-parts439021.html |
I will use the thick gasket. Should be good.....
I do not think Ford used those other fancy type spacers...... ![]() Awesome!
aquartlow ![]() Senior Member ![]() ![]() Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 1928 |
1972 had a Ram-Air option so Ford may've ditched the EGR & any spacers for hood clearance? Anderslober, are the large secondary throttle bores perfectly round or are they an odd egg shape? ![]() |
wow...never seen that before! Didnt even check that....will check! It is even difficult to see on my pictures.
IF they are egg shaped......then what?
that's what DeTomaso did to the stock intake to allow the use of a square flange Holley carb i just wondered if somebody did the same to yours, hard to see from the pic all's well carry on! |
Tweet
