  New Posts New Posts RSS Feed - Carb spacer
Carb spacer
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: Carb spacer
    Posted: 09-May-2021 at 3:44PM
I am planning on putting a carb spacer on my engine but need some info.  My car is a 1973 GTS with a 429.  It has an Edelbrock performer intake and a Holley 4150 carb.  I was wondering if anyone else has this combo and if there will be a problem with hood clearance if a spacer is used.  Also if anyone has this combo with a spacer how thick a spacer was used.  thanks. -  Dave
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2021 at 8:29PM
you should be ok with 1/2" spacer
 i have a offenhauser 4v intake a 1/2" phenolic spacer a 600DP holley and the air filter has clearance...
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 6:29AM
I run a 1" thick phenolic spacer on my 472 with an Edelbrock Performer and 4150 carb, with using a 14x3 air filter(minimum for a BBF),within a stock Lincoln drop base lower air cleaner assembly and an aluminum air cleaner lid, the front of the air cleaner is above the hood line about 1/2-3/4" (I cut out hood for air cleaner). Installing a 1/2" spacer instead and a different drop base air cleaner, may just allow your non-modified hood to close. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2021 at 8:53AM
Sorry I never got back on this, I am going to try a 1 "phenolic spacer and then play with a drop base air cleaner to see if I have enough space.  Thanks for the responses. -  Dave
