  New Posts New Posts RSS Feed - charcoal canister line
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: charcoal canister line
    Posted: 31-December-2018 at 8:22AM
Have a quick question I hope someone can give me some guidance on.  I have a new tank to charcoal canister line for my 73 GTS, bottom of body freshly painted and sitting on frame, is there any way to install the line by the rear end section without lifting the body off the frame?  I have done one short attempt at it but am not sure it can be done with the body on frame due to the small gap availiabe above the rear end section and I really don't want to scratch up the body if at all possible.    thanks  -  dave
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2019 at 3:55AM
i did mine with the body off. but you are right, thats a tight fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2019 at 7:51AM
After playing around with it for a while I'm afraid I will have to unbolt the passenger side body mounts and jack it up a little to get it in.  Another question I have is the engine has been rebuilt with new intake so the canister will not be hooked up to the engine.  Will the venting process still function without problems if the line is just running from the tank to the canister and do I just plug up the other canister opening?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2019 at 8:10AM
depends if the canister valve is normally open or closed, the other hose must be the vacuum signal from the engine to tell the valve what to do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2019 at 8:12AM
 probably won't vent if it's plugged
 i removed the canister and tucked the hose from the line inside a hole in the frame near it Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2019 at 8:15AM
a small fuel filter works nice to protect the opening and still let it breathe
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 02-January-2019 at 2:04AM
The hose from the canister to the engine was gone and left open on the canister when I got the car, was planning on putting the line and canister back on but since it probably doesn't serve its' original purpose anymore I will probably go with the filter set-up.  The only question I would have is the issue of fumes coming from the tank through the filter.  It seems like I remember reading about this in another post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-January-2019 at 4:07AM
i remember someone mentioning that, but i never smell any on my car FWIW
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 02-January-2019 at 5:39AM
Thanks, John and Rock, I will probably just do the filter then.  I don't think it's worth the time and effort to lift the body just to hook up a non-functioning part of the system.
rancheromac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2019 at 5:06AM
doing a 460 swap in 79 ranchero. are you saying I don't need to keep the charcoal canister in the mix ? doing an electric fuel pump ? thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2019 at 10:54AM
you don't need the charcoal canister! it was part of the california b.s. someone thought the tiny bit of fumes would be bad for the environment. charcoal filters the air around it 24/7 so it's usefullness was used up 39 years ago! remember this mentality comes from an era when they thought spray cans caused holes in the ozone and created smog LOL which was caused way more from leaking freon from a/c units everywhere
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2019 at 1:55PM
Ozone hole. The earth's magnetic field pulls in at the magnetic poles and does not protect the ozone layer from solar wind/radiation at those locations.
Earth's atmosphere generally is stratified, and no explanation was ever given to how a gas that is heavier than air travels eight miles up, through two boundary layers and attacks the Ozone.
Other issue was the big hole was over the South magnetic pole. Most Freon use/release was in the Northern hemisphere, no explanation as to how it travelled all the way down there to do the dastardly deed.. Normally, what happens in the Northern hemisphere, stays in the Northern hemisphere.
Maybe AlGore (Con Artist/Hippocrite/ManBearPig/Swamp Thing) can make a scam scary movie about it, next.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2019 at 4:37PM
i thought Jaara stole the ozone?
Edited by Rockatansky - 06-January-2019 at 4:37PM
This page was generated in 0.113 seconds.
