Forum Home Forum Home > General Discussion > Tools
  New Posts New Posts RSS Feed - Chicago electric 90A
ZCowher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZCowher Quote  Post ReplyReply Direct Link To This Post Topic: Chicago electric 90A
    Posted: 21-May-2015 at 2:05AM
I recently bought a Chicago electric 90A Flux core welder that came with a hobart hood, gloves. Also an esatman sandblaster with hood all for $75. Couldn't pass it up. I tried out he welder last night at the school and seems to work pretty good outside of a lot of spatter. I was told to expect alot of spatter out of flux core but is there a wire that may spatter less? I have a small hole to patch up in the front of the floor pan.
I', running harbor feights .030 wire through it now. Any suggestions?
ZC
2011 GMC Sierra Z71
73 Gran Torino H code (H is for HOTROD !!)
72 F code 4-Door
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2015 at 10:44AM
Get rid of the HF wire and get some good Lincoln or other name brand.
Not much else you can do about the spatter though. That is the main issue with any flux core wire.
You can buy anti splatter stuff to help remove it easier, I haven't gotten that far yet.
I've got the same welder, didn't get quite the deal you did but it was cheaper than at HF new and came with an auto darkening helmet. I just got a small welding table this week and need to give the welder a good workout.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2015 at 4:04PM
yes, flux core does that Angry but something else to keep in mind, is flux core can draw moisture out of the air and weld poorly just like flux coated stick rods will! so i suggest when you aren't using it for a while store the wire somewhere warm and dry as you would with stick rods if you use them. i have an old insulated camper "icebox" with a lamp socket and a low wattage light bulb inside to keep my rods dry Wink (don't laugh it works!!!)
rough_72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rough_72 Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2015 at 5:45PM
Also drop wire size and tip. If your at .030 drop to .027/.025 you can get good wire and tips at most hard wear stores. I have a craftsman 110 volt that I use and as long as you weld slow and hot it works great the splatter does come off easy. I am going to pit the gas reg on mine here soon.
AJ McKenna
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2015 at 5:51PM
yep, 75% argon/25% CO2 and .023 wire...you'll think you "died and gone to heaven" so to speak!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2015 at 6:29PM
Problem with the welder the OP and I both have is they are not convertible to gas.
Russ
swampbug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swampbug Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2015 at 4:51PM
I'm looking into getting a welder now as well. Only experience I have is with an arc welder, and it's limited. Eventually I want to do all the metal work on my car. Is it possible with just wire feed, or do I need to use gas as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2015 at 5:20PM
like in the above posts: gas works so much nicer!!! i don't think i mentioned the brand welder i use... older model  lincoln SP100  (110 volt) for sheet metal body work, i've owned and used it for many, many years no problems perfectly reliable!!! i figure it's payed for itself 3 or 4 times over! Big smile
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2015 at 11:12PM
I don't think they sell flux core in .023. I have a MIG 135 from Eastwood and that thing would slpatter like no other at first, I then bought some Lincoln wire and played with it enough to find the sweet spot. I do rarely see any splatter, welds are healthy and clean, not as nice as the big Miller we have at work but I put that on the wire/gas. For flux wire, I think it is hard to do any better now, I tried a couple other welders and results are the same. On a side note, going flux wire with a bottle of argon makes it a lot more forgiving on the welder setting.
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2015 at 11:20PM
For the past thirty years or so, I have also used a flux core 110 welder that is not convertible. I also get splatter, but it is not too bad, but I never use cheap wire.
JT, USAF Ret.
1971 Ford F100 "Lizzy"
1984 Chevy Silverado "Sylvia"
2013 Chevy Silverado "Bubba"
