  New Posts New Posts RSS Feed - Coyote 5.0 into 73 Ranchero GT
 Post Reply Post Reply Page  123 5>
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Topic: Coyote 5.0 into 73 Ranchero GT
    Posted: 04-December-2016 at 7:49AM
Well I picked this Ranchero up this weekend. Found it on craigslist with no pics so didn't pay much attention to it. After a few weeks, I texted the seller and asked for pics. Also negotiated the sale for $2000.
It's a 73 Ranchero GT. The car has 40k original miles. It decodes to Blue Glow paint, C6 trans, 3.00 open 9" rear, blue vinyl interior. The DSO is Los Angeles, which backs up my thoughts of this being a CA car. The engine code says it's a 400, but the sticker on the valve cover says 351m, so I'm going to need to pull a spark plug and measure the stroke to see what it actually is.
The paint has definitely seen better days, and there is some surface rust, but the car is unbelievably solid. It definitely has potential. The interior isn't bad either. The dash pad is cracked, but otherwise the interior is pretty nice.
Right now I'm not sure what I'll do with it. I was thinking satin black, dark brushed finish trim, grille, and head light buckets, and lowered down. But then again.... blue glow paint with some magnums or polished aluminum slots would look killer too. That's the same color as Sabatoa's Torino, and I love that car.
Anyway, here's some pics. Any feedback would be welcome :)
Edited by Power Surge - 26-December-2016 at 2:14PM
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 8:03AM
Engine code h means one of three 351w 351m or 400 I believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 8:11AM
the valve cover sticker can be confusing, it'll state engine family on one line and then the actual displacement on another. the harmonic balancer might be a clue, the original 400 had a heavier balancer than the 351M, same 28.x oz imbalance value & interchangeable but the 400 had more mass in the outer ring
unfortunately the engine block & head castings share the exact same ID codes for both engines, the only differences are the crank (& balancer), the pistons and the valve cover sticker
1973 Ranchero, possible candidate for the FMX block ... Exclamation
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 9:47AM
the valve cover sticker can be confusing, it'll state engine family on one line and then the actual displacement on another. the harmonic balancer might be a clue, the original 400 had a heavier balancer than the 351M, same 28.x oz imbalance value & interchangeable but the 400 had more mass in the outer ring<div abp="1030"> <div abp="1031">unfortunately the engine block & head castings share the exact same ID codes for both engines, the only differences are the crank (& balancer), the pistons and the valve cover sticker<div abp="1031"> <div abp="1031">1973 Ranchero, possible candidate for the FMX block ... Exclamation
Yep, I'm well aware of the sticker layout, that's what caught my eye. The engine family line says 351m/400, but the displacement line says 351ci.Unfortunately the right half of the decal is gone, so it's missing the part that says the year. The engine build sticker on the passenger valve cover is long gone as well.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 10:16AM
If it says 351m/400 the engine is '75 or newer. 351m wasn't out till 1975, so it wouldn't be on the earlier sticker.
As far as I remember, the 351c had their own stickers not shared with 400.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 10:19AM
pretty sure in 1973 the H code could be a 351C-2V or 351W-2V or 4V(rare)
400 would be an S code and 351M didn't exist until 1975
351C-4V was a Q code
some stickers said 'Cleveland Family' or such then designated displacement, not sure what year that was but i don't have a saved pic
at this point anything's possible, original engine that's worn several sets of valve covers or complete engine swap
check that bellhousing to see if it's the large or small pattern
Edited by Rockatansky - 04-December-2016 at 10:25AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 10:46AM
Now that's an interesting point...
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 11:08AM
Engine code in the VIN for 400 would be an "S"
No 351W 4bbls after 1969, until a few 80s-era Bronco/F150...
Also, it may just be the picture, but the driver side looks like a Windsor-type valve cover.
There's usually a raised square area around the oil fill on any of the 351C/M/400 valve covers
Edited by Big Bird - 04-December-2016 at 11:11AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 11:20AM
The car is an S code. And it is the picture. It definitely is a 335 series engine.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 12:50PM
hard to see but doesn't look like a windsor.
 bed looks great wonder if the primer on the lower quarters are due to surface rust from rock chips?
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 1:03PM
Nice car!  I look forward to the progress!
You're right they didn't share the same stickers.  The early 400's list the engine family as "400" like this one here:
The 351's listed the engines family as either 351C or 351W.
After 1975 when the 351M came out, the 400 and 351M used the same engine family "351M/400" but it will also list the actual displacement below like this one for a 351M.  Its surprising how many people think that a 351M/400 is actually one engine.
Edited by 72FordGTS - 04-December-2016 at 1:04PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 4:00PM
Does anyone know if the 73-76 GT stripe was originally painted or a decal?
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 4:02PM
The original stripes are decals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 4:24PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 4:31PM
http://phoenixgraphix.com/
Yep...used them for many years now. Just wasn't sure if original was painted or decals. (thanks dave)
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Torino_Chris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torino_Chris Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2016 at 9:19PM
That is a really nice color! Shocked I'd stick with that if I were you!
1988 Porsche 944
"...what's it all about, guess it just reflects my moooood..." ;) (The Rolling Stones)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2016 at 11:55AM
Well after a few days of research and checking casting numbers, I am quite certain that the engine is a 76 351M. Not that it's all that important....from the outside it's the same as what came in the car, and it's not a rare engine code or anything. But nice to know.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2016 at 3:07PM
easy enough to restore back to 400ci if you ever decide to go through it
or maybe a few more Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2016 at 3:43PM
I like the blue with the stripe too, looks very sharp.  I agree with Rock, not much too much to make it a 400 or better yet a 434 stroker....
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2016 at 4:06PM
400 engines are getting popular with builders now. Kind of a dare to be different. I'd stay with the Blue Glow and perhaps go with a Laser stripe if you could get one to work instead of the Ranchero stripe. Either way, nice find.
1972 GTSquire Wagon
