  New Posts New Posts RSS Feed - Coyote 5.0 into 73 Ranchero GT
 Post Reply Post Reply Page  <1234 5>
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 26-December-2016 at 2:36PM
So I was planning to put this drivetrain into a different vehicle, but decided to sell of that car and put this into the Ranchero. It's a Coyote 5.0 motor, and a TCI Streetfighter C4 (with some upgrades), and a Performance Automatic bellhousing.
I'll post pics of the progress as I work on it. Big smile
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2016 at 2:21PM
Got the PCM today.... will be sending it off to my buddy to disable the PATS. Just collecting parts right now. Will be pulling the nose off the car soon :)
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2016 at 2:25PM
Great project! If you don't mind, could you give me a ballpark idea of the cost to disable the PATS? I am using a wiring harness from a Mountaineer that was so equipped. Thanks.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2016 at 2:28PM
Joe, if you're using something older, it can be done in the tune. Unfortunately the Copperhead PCMs (5.0 processors) can't be turned off by the tune itself. It has to be physically modified.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2016 at 2:48PM
see that's why i like carburetors! all you need is a small screwdriver to tune them WinkBig smile
74 CORVETTE COUPE CUSTOM
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2016 at 5:16PM
curious, why run a c4 and not a Od trans?
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2016 at 3:22AM
Cheaper, easier, smaller, more aftermarket support, more trans tunnel clearance, no need for electronic control, and crusing rpms won't be that much different with 3.00 gears then an OD trans with higher gears.
Plus I had it... this swap was originally going in a MustangII.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2016 at 3:35PM
Got the nose pulled off today.... only one broken bolt!  lol
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2016 at 4:33PM
 Clap yeah i only had one broken bolt on mine too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 12:52AM
Dang, even with the front sheet metal off, that is one clean looking (survivor)Ranchero. Sounds like an awesome project, I am more of a BBF guy but those Coyote's are great power plants! BTW, I'm envious of the garage/man cave. Good luck on the project and keep us posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 3:56AM
That is very clean. Noticed the good-looking bias ply tires. What fun it would be to roast them with Coyote power.
1972 GTSquire Wagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 4:03AM
Don't be jealous...that's not a man cave (I wish!). That's my work.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 4:04AM
Those wheels definitely won't be on it when it's done Wink
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 1:16PM
Radiator, support, and related removed. Everything else disconnected for engine/trans removal.
Also scored a TCI 10.5" 2800 stall converter for $150. Should work well with this setup. Smile
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 1:38PM
Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 1:49PM
Good time to check upper/lower control arm bushings and ball joints(get right at 'em)
Edited by aquartlow - 31-December-2016 at 1:50PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2016 at 1:58PM
After everything for the conversion has been fit, I plan to take apart the entire front end and refinish and replace everything. Might end up with different upper control arms anyway, for exhaust clearance.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
DaleR09 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaleR09 Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2017 at 3:50AM
Have you thought about doing a Crown Vic front crossmember / suspension on it? Was thinking that the Coyote is a rear sump pan, and the old suspension is a front sump / rear steer.....
'72 Ranchero GT Q code
'72 Ranchero GT H code
'03 Ranger 4X4 Stepside
'03 F350
'14 Fusion AWD Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2017 at 4:05AM
hmm, good idea
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 01-January-2017 at 4:32AM
Cool project!  Looking forward to your updates and progress.
I'm digging that 66-67 Fairlane in the background.  Assuming that's not yours?
Jeff
79 Ford Thunderbird w/ T-tops
