Cyclone original carburetor. |
Anderslober
Senior Member Joined: 30-July-2019 Location: Denmark Status: Offline Points: 763 |
Posted: 06-February-2020 at 3:24PM |
Hello forum......I just bought a project-Cyclone. What was the original carburetor used on the 1970 N-code (429) Cyclone?
See picture of the engine bay....is that a Holley 4150? I have not seen the car in real life yet. It is being shipped as this is being written. |
handsofstone
Motorcraft would be my guess.
Maybe a 2nd day mod? My first GTS had dual feed vac secondary Holley 650 and original owner told me it was purchased that way. I would have loved to get a marti report for the car wven though carb would not have been listed. Does the car run?
Anderslober
Yes....the engine does turnover and chirp. That was a requirement for purchase. It does need a TOTaL tune up though.
it's a holley, duel feed vac. secondary with manual choke from what i can see, the list # on the front of the air horn will tell you what it is
Anderslober
Hi Johnny......you dont have time for this....you need to be choppin up a Torino..hehehe
The original carb for this year/engine....was it Motorcraft 4300? I do realize the Holley may be a better carb........
handsofstone
Here is where the number is stamped. That will give you all the info you need to get rebuild kit.
handsofstone
That carb is an early original I suspect and will work to perfection unlike the new ones which need tlc.
i should be chopping this weekend we should be getting a break in the weather
Anderslober
Yes...I have tried to zoom in on the carb many times to see if I could see the model number The car is in a shipping container now, so I wont be able to check for at least another month.
The Holley is a great carb....but, was it the original carb for this engine/year? Or was the Motocraft 4300? Of course the (Holley) carb will get a total refurb.
IDK? some cars were factory with a holley. see if it has an adapter plate under it? the 4300 is wider in the rear at least the ports in the intake are...
The original carb for the N-Code 429 Thunderjet is a 4300A squarebore carb, not a spreadbore like the 4300D. The 429CJ used a Rochester QJet and the 429SCJ used a Holley.
Here is a thread where we discuss the carb for a N-code 1970 Torino, which is the same as your Cylcone. |
