  New Posts New Posts RSS Feed - Dash panel fix (radio opening)
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: Dash panel fix (radio opening)
    Posted: 04-May-2019 at 7:25AM
I am looking for suggestions on the best way to refurbish a dash radio opening which has been cut much bigger than original.  I would like to use a factory radio but the p/o put an aftermarket radio cassette player in and left a large opening. I am wondering if anyone has restored the panel to a somewhat stock condition somehow or has used a kit to re-adapt a factory radio to the larger opening.  thanks  -  dave
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2019 at 9:00AM
i made an aluminum overlay out of a road sign to cover the whole recessed area and bolted it onto the original section since mine was not only hacked but broken out as wellShocked then painted it flat black.
 another option would be to trim a good original section and glue it over the whole section with ABS pipe glue Wink
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2019 at 1:44PM
I used textured ABS plastic and made a overlay panel
Owner- www.CaNDeCustoms.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2019 at 3:38PM
i have 2 dashes i could cut that whole good section from... if your interested
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2019 at 4:39PM
John, I think I'll try the abs plastic method Carl suggested first and if that doesn't turn out well I will definitely get back with you, appreciate both responses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2019 at 7:34PM
ok
KarlB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KarlB Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2019 at 12:35PM
I have the same problem. Is the damaged area a separate piece of the dash assembly? If so, can it be removed and replaced with an intact part? Probably a major project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2019 at 5:26PM
no, it's all part of the entire plastic dash surround
Post Options Post Options   Thanks (0) Thanks(0)   Quote KarlB Quote  Post ReplyReply Direct Link To This Post Posted: 13-May-2019 at 12:27AM
Thank you. It seems I will need to purchase an other dash. Sadly I am a perfectionsist, so patches usually don't work for me. thx Karl
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 15-September-2019 at 6:44PM
Carl, what thickness did you use for this?
Thanks,
Russ
