Dash panel fix (radio opening) |
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 614 |
Posted: 04-May-2019 at 7:25AM |
I am looking for suggestions on the best way to refurbish a dash radio opening which has been cut much bigger than original. I would like to use a factory radio but the p/o put an aftermarket radio cassette player in and left a large opening. I am wondering if anyone has restored the panel to a somewhat stock condition somehow or has used a kit to re-adapt a factory radio to the larger opening. thanks - dave
Dave - 1973 GTS N code
i made an aluminum overlay out of a road sign to cover the whole recessed area and bolted it onto the original section since mine was not only hacked but broken out as well then painted it flat black.
another option would be to trim a good original section and glue it over the whole section with ABS pipe glue |
Regul8r 2
Admin Group Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
I used textured ABS plastic and made a overlay panel
Owner- www.CaNDeCustoms.com |
i have 2 dashes i could cut that whole good section from... if your interested
1973gts
John, I think I'll try the abs plastic method Carl suggested first and if that doesn't turn out well I will definitely get back with you, appreciate both responses.
ok
KarlB
New Member Joined: 21-April-2017 Location: Louisville, KY Status: Offline Points: 21 |
I have the same problem. Is the damaged area a separate piece of the dash assembly? If so, can it be removed and replaced with an intact part? Probably a major project.
no, it's all part of the entire plastic dash surround
KarlB
Thank you. It seems I will need to purchase an other dash. Sadly I am a perfectionsist, so patches usually don't work for me. thx Karl
russosborne
Carl, what thickness did you use for this? Thanks, Russ
