  New Posts New Posts RSS Feed - Deck lid drains
Deck lid drains
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: Deck lid drains
    Posted: 05-December-2017 at 8:00AM
As I was blasting the seam sealer from the underside of my deck lid, I noticed four drains along the trailing edge of the panel. I'm going to assume these were to drain out any excess primer as the panels were prepped and then were sealed when the seam sealer was applied to prevent moisture from bypassing the trunk seal.
Is my logic correct?
THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-December-2017 at 3:20PM
i don't think ford primered or painted the back sides of the metal just what got sprayed after it was assembled that's why these cars seem to rust out over the years Cry i sealed up my trunk drain holes too Embarrassed but i don't plan to leave my car out in the elements! not after all the work i did! i also sealed around all the inner bracing just to keep moisture out
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2017 at 5:36AM
Thanks John for the confirmation.... yeah I noticed that Ford didn't apply any primer/paint back inside the the deck lid but rest assured I WILL after all the effort I've put into my build! Beer
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2017 at 7:02AM
underhood is the same way. my 37k mile and garaged its whole life car leaves rust scale from the under side areas of the hood not painted on the top of the core support and the cowl from the hood. Not sure how I'll address that  Confused
Past 1974 Ranchero GT Q code
