  New Posts New Posts RSS Feed - delayed wiper switch
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: delayed wiper switch
    Posted: 12-July-2017 at 5:28AM
Does anyone know were it mounts under dash.At 72 I would like to have an idea were to look before I attempt to get under the dash.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 7:54AM
The connecting wires from the wiper switch to the delayed wiper relay are very short, so it should be mounted right behind the wiper switch in the dash board. The other short wires are for the connection plug to the wiper motor.
There are three pictures below of the wiper motor switch, the delayed wiper relay and the connection plug to the wiper motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 7:55AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 7:56AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 9:31AM
The bracket for the wiper governor mounts between the wiper switch and left knob of the radio on the firewall side and above the lower portion of the dash. There is a metal bracket that runs across the bottom of the plastic dash, which reinforces the lower dash, the governor mounts to that. The mounting screws for the governor go through the plastic dash, the metal reinforcement bracket then thread into the governor mounting bracket. The screws are spaced about 1.5-2" apart(been a while since I messed with my interval wiper governor) and are blunt on the end to keep from piercing wires under the dash. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 5:54PM
on the 77-79 cars it's mounted to the dash brace like todd said, on the earlier cars it's mounted to the upper plastic part of the dash above the gauge cluster Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2017 at 7:36AM
Thank you was trying to mount near steering column but could only find one hole.Lets be true took 2yrs to find the plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2017 at 7:40AM
Your welcome
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2017 at 5:51PM
bob, when i added the delay unit assembly to my car, i didn't know where it mounts so i just drilled a 1/8" hole with a self tapper screw to the steering column brace Confused I've since found where they mount having remove some from cars Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2017 at 11:40PM
Thats were I was headed
andrewok1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewok1 Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2017 at 11:25AM
i MOUNTED MINE A COLUMN BRACE. its all good just do not pinch wires
GET IT GOT IT GONE !!!!!!!
