Distributor swap |
Rivercrest
Member Joined: 07-December-2019 Location: Manitoba Canada Status: Offline Points: 175 |
Posted: 11-September-2020 at 1:23AM |
Just wondering if the dist assembly from a 351M is swapable with a dist from a 351C......1974 Vintage.
72 RS 351
Thanks(1)
Yes, the distributor is the same for a 351C and the 400/351M engines. The Windsor is also the same except for the cam gear on the bottom.
Rivercrest
Thank you, I appreciate the on going knowledge of this forum........
The Torino Kid
Senior Member Joined: 23-November-2003 Location: United States Status: Offline Points: 250 |
the distibutor from a 429/460 engine is the same as well.
1973 Gran Torino Sport CJ 351
'Q' code 63R body |
BadHabit351
Senior Member Joined: 21-June-2013 Location: United States Status: Offline Points: 217 |
I've never heard that before. Hmmm....
1973/72 Gran Torino Sport
1971 Torino GT convertilble 2013 Ford Fusion 2004 Ford SuperDuty 2013 Mustang GT |
housing height can be different especially across aftermarket mfgr's
Curious on the 302 housing being smaller... We used to swap oil pump, pump drive, and distributor form 351W into 302/289 engines for durability. Don't remember housings having a fitment issue...
72 RS 351
The 302 diameter is slightly smaller, I've seen sleeves made to let the 302 cam synchronizer from 96-01 Explorers go into a 351W.
