Don't be a dipstick.... |
73torino gt
Senior Member Joined: 12-July-2013 Location: Lincoln ND Status: Offline Points: 327 |
Posted: 28-August-2014 at 5:14PM |
DOAE 6750 A with an M.Is this the right one for a 351cj?
dave302
Yes, this appears to be the correct dipstick for the '73 351cj. Maybe one of the other members will know this for sure and/or can look at their part and confirm this.
The DOAE 6750 A was also used on the 1970 351 cleveland M-Code engines.
dave302
There is a picture below of a DOAE 6750 A dipstick from a 1970 351 cleveland M-Code engine.
Edited by dave302 - 09-February-2016 at 8:42PM |
dave302
Notice that there is the also the "M" to the right side of the DOAE 6750 A part number.
Edited by dave302 - 09-February-2016 at 8:26PM |
dave302
Edited by dave302 - 09-February-2016 at 8:34PM |
dave302
This part number is the same part number for the dipstick that is also used on the 1972 and 1973 351 Cleveland H-Code 2 barrel engines.
If someone can confirm for sure that they had used the same exact dipsticks on the 1972 and 1973 351 Cleveland H-Code 2 barrel engines and the 1970 351 Cleveland M-Code engines, as they did on the '73 351 cj engines (they most likely did though) then this is the correct dipstick for your engine.
Edited by dave302 - 28-August-2014 at 8:45PM |
73torino gt
That answers that,thanks
dave302
Your Welcome.
Edited by dave302 - 29-August-2014 at 2:01PM |
73torino gt
4qrts of oil shoews full on the dip stick with an anti drainback filter?should b five right.
73torino gt
Also what is the correct length of the dipstick for a 73 351cj
dave302
73torino gt
I only put in 4 qts.total
dip stick or tube my be wrong??? most of these older cars generally held 4 in the pan and 1 in the filter, for 5 total (usually)
73torino gt
That's been my experience,I guess I need dipstick and tube measurements then.Thanks again.
bata747-8
Moderator Group Honorary Spam Bot / Zombie Account Joined: 24-June-2010 Location: China Status: Offline Points: 131 |
1975 351W had a total capacity including filter of four quarts. Terrible idea on fords part, but that engine did last 235000 with regular oil changes.
Forum Test Account
(formerly a spam bot account) |
73torino gt
Its a 73 torino 351cj,single drain plug
my two AFAIK stock 351C dipsticks are the same PN as Dave's mine don't have the 'M' after the Ford logo, mine have an 'A' and a 'B'
tape measure is even with the top of the handle loops shiny stick is Transdapt 9223 which has issues with the tube BTW, but the stick itself is pretty close to factory except the add mark is a little high meaning you'd add a Qt sooner than you would with the factory stick Edited by Rockatansky - 30-August-2014 at 4:25PM |
73torino gt
Much thanks
so what do you think is up?
is your oil pan factory? is the dip tube correct? you're sure it's a Cleveland motor?
73torino gt
Well I used the old school bumper jack on the drivers side to jack her up so im thinking a qt stayed in the pan.also I only warmed it up for 2 minutes or so.definitely a Cleveland,right dipstick ,tube not sure on nor pan.Maybe one of these is wrong or I just don't know how to change oil anymore.
73torino gt
DOAE 6750 A. M mine is 25 inches long with an orange handle.
mine are right at 24 1/2" long overall, could that extra 1/2"explain the missing Qt?
how is the 'wave' section at the top on yours, does it fill & grip the dip tube or is it flat & beat out if your wave is flat that could be the extra length & missing Qt
73torino gt
She's pretty wavey,I think ur right about the half inch and the missing qt.I just ordered one from eBay that's 24 1/2 inches.that should do the trick.I really appreciate your help on this.thank you
