Door component weights |
TV 2M8O
Senior Member Joined: 20-September-2006 Location: Southern Ohio Status: Offline Points: 2052 |
Posted: 15-December-2019 at 8:39AM |
With my car being scheduled to go off for body and paint work, I realized that my doors are gutted and empty and to properly set the door gaps, we'll need to add in the appropriate weight to approximate the door "sag" once all the pieces are reinstalled. Does anyone know what the glass, track, power window motor, power door lock actuators, release and latching mechanism, mirror, weatherstripping, exterior window trim and interior trim panel might weigh so I can get weighted bags made to place in the doors to simulate the weight?
THANKS
well it shouldn't really sag too much at all if you rebuilt the hinges idk off hand but i could weigh a glass and a latch and power motor... the rod for the track is pretty light as with the hatch rods....
TV 2M8O
OK here are the component weights for anyone interested...
DOOR GLASS: 18.125 lbs LIFT MECHANISM - MANUAL: 4.75 lbs LIFT MECHANISM - POWER: 8.25 lbs GLASS BRACKETS & GUIDES: 1.75 lbs SPEAKER (6.5") - 1.875 lbs POWER LOCK ACTUATOR: 1.25 lbs WIRING HARNESS: 2 lbs LATCH MECHANISM: 3.125 lbs EXTERIOR HANDLE, LOCK & PARTS - 1.25 lbs EXTERIOR CHROME REMOTE MIRROR: (OOPS FORGOT TO WEIGH ) EXTERIOR BRIGHT DOOR BELTLINE MOULDING: 1.125 lbs EXTERIOR BODY SIDE MOULDING & CLIPS: .75 lbs DOOR WEATHERSTRIP: 1.25 lbs INTERIOR DOOR TRIM PANEL: 7.75 lbs ARM REST ASSEMBLY: 1.50 lbs I'll add the mirror weight next time....
Edited by TV 2M8O - 22-December-2019 at 6:09AM |
sorry joe, with all this crap going on here lately i forgot to weigh some parts but it looks like you got it... BTW most of that weight will be centered in the door FWIW.....
TV 2M8O
Yeah, but that weight is still outboard of the hinge, so there will be some sag. I added up all the weights associated with the components in my door and they total out OVER 50 POUNDS! I was guessing between 25 & 30......
yeah but think of the old sliding scales like at the doctors office or feed store
Thanks(1)
This is great info Joe. I may copy it and post it on the reference section later.
TV 2M8O
OK, for some reason I'm unable to edit my post, so here are the component weights INCLUDING THE CHROME REMOTE MIRRORS for anyone interested...
DOOR GLASS: 18.125 lbs LIFT MECHANISM - MANUAL: 4.75 lbs LIFT MECHANISM - POWER: 8.25 lbs GLASS BRACKETS & GUIDES: 1.75 lbs SPEAKER (6.5") - 1.875 lbs POWER LOCK ACTUATOR: 1.25 lbs WIRING HARNESS: 2 lbs LATCH MECHANISM: 3.125 lbs EXTERIOR HANDLE, LOCK & PARTS - 1.25 lbs EXTERIOR CHROME REMOTE MIRROR: DS - 2.25 lbs / PS - 2.75 lbs (I would estimate that .50 lb of the PS mirror would actually be due to the length of the operating cable so it would actually be inside the cockpit) EXTERIOR BRIGHT DOOR BELTLINE MOULDING: 1.125 lbs EXTERIOR BODY SIDE MOULDING & CLIPS: .75 lbs DOOR WEATHERSTRIP: 1.25 lbs INTERIOR DOOR TRIM PANEL: 7.75 lbs ARM REST ASSEMBLY: 1.50 lbs
