drum brake size, assuming stock |
russosborne
Posted: 13-October-2019 at 10:59PM |
Is there any way to tell what size rear brakes my 72 Ranchero has without taking them apart? I'd like to order the parts to redo them in advance. Summit has 10 and 11 inch diameter, plus one weird one at 9.9 something, and 2.25 or 2.5 inch width. Thanks, Russ
unlovedford
Brake size will be shown on the outside of the drum, flat area facing the wheel between the axle flange face and the finned edge.
i think there are a couple different sizes like joe said above and IIRC some 72's had a narrower shoe? i seem to remember a member needing a narrow drum for a 72??? but not too hard to pull a wheel and remove a drum and measure then just put it back on
unlovedford
The '76 Squire I'm stripping was a factory 460 car loaded with options. It has massive 11 x 2.5 surface area drums in back. The actual diameter and width of the finned drum itself is incredibly large, much like a truck.
These are 10" and 11" drums, 2" wide, and 2.5" wide. Brake backer plates are different for each. Pull a wheel off and look for the size stamped on the drum.Check the bolt pattern on any drums you are buying as well, 4.5" bolt pattern and 5" bolt pattern both exist.
russosborne
Thanks.
Yeah, lots of choices. Hopefully I can do it without pulling the drum. That's never fun for me. But if I have to I will. Disks are the long term solution, but not soon. Russ
