  New Posts New Posts RSS Feed - EFI to Carb Conversion on 5.0L
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: EFI to Carb Conversion on 5.0L
    Posted: 16-April-2019 at 4:16AM
For a 1990 Mark VII 302 HO, what problems or changes do I run into changing back to carb from injected on this HO 302 1990?
Edited by 72FordGTS - 16-April-2019 at 6:14AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2019 at 11:55AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2019 at 12:10PM
Besides the possible cam issues you may see that Rock mentions, there are a number of other parts you need. You'd need an new intake, and distributor.  You could use a low pressure electric fuel pump for the carb, but if you convert to a mechanical pump you need a new timing cover, and possibly a fuel pump eccentric.
There are some kits online that include some of the parts like this one that includes and intake and carb:
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2019 at 2:37AM
Well that read was way over my head. Guess I will wait until I get the car home. Evonne wants to know how I expect to work on car when I can't lift a 5 gal can of gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2019 at 9:03AM
Are you trying to swap the engine into something else, or run the Lincoln without the EFI?
Two very different sets of issues.
For swapping the engine:
EFI cam will work just fine. mine got swapped to a E303 cam, because it was available, but was originally running the factory GT cam just fine.
Timing cover will need replacement.
You can use a distributor with a steel gear (85 mustang GT with 5-speed for a source).
Engine may or may not have a fuel pump eccentric, or only the inner half of a 2-peice eccentric.
Eliminating EFI on the Lincoln, you will add computer complications, transmission control issues, emission issues, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2019 at 10:37AM
It is suppose to be going in my pinto. Though maybe carb would be easier than figuring the computer mess. time will tell. If not for the org owner stripping out all the wiring dash and all it is a rust free car.He even replaced air ride with reg coils.
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2019 at 6:14PM
You will need a carb, a carb intake, and a non EFI distributor for sure.
You will need an old style timing cover and fuel pump eccentric on the cam if you want to use a mechanical fuel pump. Not needed for an electric pump.
If you don't want to keep the serpentine belt system you will need all the accessories and mounts for the V belt set-up.
I'm putting an 89 5.8l (351W) in my 79 Pinto. I'm using the serpentine belt system and an electric fuel pump.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2019 at 4:12AM
Keeping the serpentine. 351 w that's a tight fit no room for headers with 302.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2019 at 4:29PM
They do make headers for both the 302 and the 351w swap. Have to cut the fenderwells, but I don't have the fenderwells anyway. Hoping I don't need them. Not cheap.
These are for the 351w.
https://www.summitracing.com/parts/hok-6163hkr/year/1979/make/ford/model/pinto
Summit has the ones for the 302 also.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2019 at 6:06AM
I feel they are ugly
