  New Posts New Posts RSS Feed - Emblem
Emblem
roknxj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Topic: Emblem
    Posted: 10-June-2020 at 8:55AM
Hello all,
Anyone know how to remove the emblem insert from one emblem and glue it to another emblem? See picture
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2020 at 1:40PM
You would be better off buying a new repop piece.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2020 at 1:42PM
The old one will most likely be destroyed trying to pry it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2020 at 2:38PM
i thought you had taken yours apart john...
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2020 at 3:06PM
I don't mind destroying the donor emblem to get the insert. High heat will not help?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2020 at 4:30PM
N0, my car had a 73 flipper. Bought one without the emblem and picked up a repop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2020 at 7:45PM
oh ok i couldn't remember exactly what you did
you could try heat but i wouldn't get it too hot it could melt the emblem but some heat from the back side might work???
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 11-June-2020 at 1:34AM
The one I bought from Joe had no emblem but plenty of the factory glue. Took a while to remove it since it was rock hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2020 at 4:48AM
I will give it a try after fathers day weekend. Anyone in CA going to the swapmeet in Turlock this coming weekend?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2020 at 6:04AM
Try drilling a hole in the backand pushing it out. Better yet , if replacing, use a dremel and cut the plastic in half then pop it out with a screwdriver
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 3:37AM
Heat worked. Now I'm going to repaint. Youtube has a great video on it.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 4:05AM
Cool. Post the video too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 4:36AM
Here you go:
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 6:24AM
Update started removing the paint. The easy part is done, now the hard part starts. I will need to buff the front before painting.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 7:04AM
The guy in the video sounds like Bigfoot it is. From the Stern show.
The emblems cane out nice.  Are you using the candy apple red spray paint too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 7:06AM
What does the back of your emblem look like? What did you scrape off the paint with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 8:20AM
Q-tips, Isopropyl alchohol, and a sharp  exacto knife.
Didn't take a picture of mine from the back but found one on ebay.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 10:38AM
Ok just did the first stage of polishing
can't tell from the picture but it is like glass.
Ok I was thinking of painting the crown candy apple red, the lions/cougars will stay gold and the outer will be glossy black. Thoughts comments?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2020 at 2:54PM
Nice work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2020 at 4:31AM
Nice work.
Thanks I will post picuters once i paint the emblem
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2020 at 12:25PM
Here is my first go at it. Might re
do it again.
Thanks,
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 02-July-2020 at 1:30PM
That looks great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2020 at 3:54PM
What is a good glue to use?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2020 at 5:20PM
Silicone works well. Just clean it good with alcohol or thinner.
