  New Posts New Posts RSS Feed - Engine code
Engine code
Rivercrest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Topic: Engine code
    Posted: 21-December-2019 at 9:40AM
Just a quick question, to read the engine code stamp at the rear of a 351m/400 do I need to remove the transmission? is it hidden by the bell housing? thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2019 at 3:25PM
Block casting number is behind the starter. Also, what foundry is cast into the flat behind the manifold next to oil sending unit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2019 at 4:09PM
kind of above the starter
