  New Posts New Posts RSS Feed - engine hight
engine hight
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: engine hight
    Posted: 14-July-2016 at 5:16AM
Does the351m set higher in engine comp that 351w or do motor mounts make them the same.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2016 at 7:44AM
The 351m is 0.794 inches (25/32") taller than the 351w, but i do not know if the motor mounts make them set the same. I will take a guess an say yes, the 351m sets higher in the engine compartment than a 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2016 at 10:29AM
351M is noticeably taller/wider in the engine bay than a 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2016 at 5:32AM
you would think that the crankshaft center line would be nearly the same for all engines?
the deck height of the block is a big factor in how tall the engine looks / is, and the size
of the heads adds to that.
351W heads are small, same as 289/302/5.0, while 351M heads are big square blocks
almost /if not the same as 429/460 height-wise
approx deck heights;
302 = 8.2"
351C = 9.2"
351W = 9.5"
351M = 10.3"
460 = 10.3"
the 351M/400 appears as large as a big block in the chassis
Edited by Rockatansky - 17-July-2016 at 1:53PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2016 at 10:44AM
Crankshaft Centerline should be in the same place to keep transmission angle consistent, which keeps driveshaft angle consistent, which keeps u-joints in step with each other, and pinion angle...etc....
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2016 at 10:32PM
Also the fan center line is the same as the shroud is the same for all the cars too.
Owner- www.CaNDeCustoms.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2016 at 3:29AM
IIRC there are 2 different shrouds to cover all engines
