  New Posts New Posts RSS Feed - Engine question...
Engine question...
formulacc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote formulacc1 Quote  Post ReplyReply Direct Link To This Post Topic: Engine question...
    Posted: 14-June-2018 at 2:49PM
Ok, got the Cougar 2 months ago, when I gave it a quick once-over, I saw on the emissions label on the left valve cover that it was a 351...part of the 351M/400 engine family....which is fine.  Using my new parts catalog today, I was doing some more decoding of things, and realized the 5th digit of the vin is an H, which, according to EVERYTHING I've read, denotes a 351W...BUT...according to the tag on the right valve cover (which, amazingly was still legible) it is a 351M, along with the fact that it has 4 bolts at the bottom of the valve covers, and the t-chain cover is part of the block, not bolted to it confirms it's a 351M.  I'm guessing it may have been replaced at some point, but the car was built on April 24, 1978, and the engine was built on April 17th...I wonder what the odds are of it getting an incorrect engine out of the box, or maybe someone out there has seen this before??  VIN is 8H93Hxxxxxx....tag#'s on the valve cover are JJ548BE.....might be time for a Marti Report....
1985 Chevrolet Corvette
2009 Chevrolet Avalanche LT
2011 Volvo C30
Adam
Remember: no matter where you go, there you are.....
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2018 at 2:59PM
H can be either a 351m/2v or a 351w/2v, has always been that way UNLESS it was a 4 bbl engine, then it got either a M (older 69-71 torinos) or a q code (our era cars).
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2018 at 3:39PM
H can be 351w 2v, 351c 2v, or 351m 2v
Post Options Post Options   Thanks (0) Thanks(0)   Quote formulacc1 Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2018 at 12:09AM
gotcha....like I said, I knew what was there, didn't understand why.....seems odd that Ford wouldn't make that a VIN-specific choice....
2011 Volvo C30
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2018 at 8:22AM
they're always running out of numbers and letters / NOT lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2018 at 6:57PM
Ford has done some odd things over the years from what i have learned. some very strange things happened on the line back in the 60's and 70's, it was the sex/drugs/rock n roll era after all. Just talked to a guy who bought a new 67 fairlane with a 390 2v. he went to get the motor rebuilt a few years ago and turns out it was a 428, now how in the heck did that happen?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2018 at 7:26PM
sure it wasn't supposedly a 427? mold cores got swapped around, some are famous
https://www.ford-trucks.com/forums/281611-did-390-blocks-have-427-cast-in-them.html
Edited by Rockatansky - 15-June-2018 at 7:27PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2018 at 5:43AM
no, it was a honest to goodness 428 where a 390 should have been.
