  New Posts New Posts RSS Feed - English Wheel\Jewlers Wheel
Don V. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Topic: English Wheel\Jewlers Wheel
    Posted: 23-September-2017 at 4:46PM
These small wheels use to be common with jewelers, model makers, pattern makers, etc. but I can't source one anywhere. Does anyone know of a source?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2017 at 5:52PM
some leads
central machinery 97359
looks like you could make one out of a C clamp ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2017 at 5:56PM
never seen a small one like that? kinda cool! might try ebay just for the hell of it never know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2017 at 9:29PM
I've been to ebay many times hoping one day one would show up. No luck so far. You're right that they are cool. Scale the metal to what you want to make and the results are the same to a full scale part. Without a lot of cost involved, difficult fabrications can be practiced and worked out before going to full scale. Using one also allows for getting away from breaking up body panels in to pieces that need to be welded together.
Rock, thanks but no luck. The C clamp wheel has been around for a long time but they have too much spring in them. There's a fair bit work hardening that happens that doesn't translate to a full sized wheel. The process that you develop on the small wheel isn't what happens on a large wheel. A good wheel anyway. They're good for parts that are completed on a small wheel like a model maker fabricates.
