  New Posts New Posts RSS Feed - epoxy primer
epoxy primer
ohheadache View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ohheadache Quote  Post ReplyReply Direct Link To This Post Topic: epoxy primer
    Posted: 18-January-2014 at 2:51PM
i need help please i just picked up for free 1 gallon of epoxy primer and the catalsat it says 1-1 mix
my question i need the mixing formual  . want to mix 1qt at a time how much of each part do i need to mix to make a qt   thanks  dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2014 at 4:04PM
that means 1 part primer to 1 part catalyst : so if you want 1 qt of ready to spray material you mix 1/2 qt primer and 1/2 qt catalyst = 1 mixed qt ready to spray.  (1/2 qt is 1pint)
Edited by californiajohnny - 18-January-2014 at 4:06PM
robot9000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robot9000 Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2014 at 3:45PM
If you want to do smaller batches, go to a paint job shop and pick up the measuring cups. They are calibrated to allow you to choose your ratio and pour your epoxy to line x then add cat to line Y and you have the right amount.
2010 Mazda 6
2007 Jeep Wrangler
2011 Damon Daybreak 35BD
