  New Posts New Posts RSS Feed - Factory Tach problem
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Topic: Factory Tach problem
    Posted: 11-January-2008 at 10:34AM
tried hooking it up as prescribed (in line with the power wire to the coil) and at a 1000 rpm idle it sits at 3000 rpm...  It swings around almost normally when revving (right to 6000 when revving to 3000 rpm).
Any thoughts?  (especially how to fix)
Crane HI6 ignition with PS92 coil and MSD billet dizzy...
TIA,
Jim
1976 S&H Gran Torino
460/C6/4.33 13.05@105.6
545/C6/3.56 11.52@117.8
460/T56/4.00 cruiser
www.torinocobra.com
www.starskytorino.com
Flipvs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2008 at 7:37AM
Jim,
I don't know the Crane ignition, but like more electronic ignitions it could be that the Crane fires more than one time on a single pulse.
In this case there's not much you can easily do .
There is a way though, and that is to use an optical or magnetic sensor on the crancshaft pulley, and generate (with an  electronic booster) a current
pulse of  about 1 Amp. trough  the factory tach.  That  should  do the job.
Maybe you could first test  the tach (to be sure it's working)  with a small transformer, outputcurrent 1 Amp. , voltage not very important,  a single rectifier diode.
At 60 Hz it would result in a tacho reading of 3600/8=450 rpm.
If you need a schematic  diagram of the test setup,  I'm glad to help you.
Flip.
ps
Are you sure the tach is originally for an eight cyl. engine?
Edited by Flipvs - 13-January-2008 at 10:54AM
Gran Torino'73 Wagon, 351c, Goldglow, sportsmirrors, sportscluster, cold airc., Bi-fuel: Petrol+Propane(LPG), Pertronix ignitor1, 2 Oxygen Sensors and a daily driver !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2008 at 11:42AM
I'm scratching my head.. sell the crane and go MSD :) Actually, what year is your cluster? 74 or older?
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2008 at 4:38PM
The tach actually came out of a 1974 Torino (351C), would that be the problem?  IIRC they had points and a resistor in the wire..
FWIW, I will never put another MSD on the car, three is enough..
I have access to two 1976 tachs, worth trying them?
Jim
www.torinocobra.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 14-January-2008 at 12:34AM
If it comes out a '74 351, that's ok.
Or your tach isn't working properly, or the ignition is causing the problem.
Trying the other tach is always an option.
At least you will be sure about the status of the one you're using at the moment.
ps
Have you any idea of the current flow through the coil ?
It could be that it's much too high for the tach.
In that case there would be a simple solution, of shunting the tach with a resistor. Maybe you can measure the current flow, I can compare it with my tach-current.  Maybe that could give the solution to the problem.
Flip.
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 14-January-2008 at 1:53PM
Current as in amps?
Jim
www.torinocobra.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2008 at 9:45AM
Yes, electric current.
Measure it in one of the coil-leads. (about 3 to 7 amps I guess)
Flip
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2008 at 11:21AM
Ok, I will give that a shot and report the results..
Thanks!
Jim
www.torinocobra.com
