  New Posts New Posts RSS Feed - Factory Tach
Factory Tach
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Topic: Factory Tach
    Posted: 14-December-2007 at 10:02AM
Can anyone help me get this to work with the Crane ignition/MSD dizzy?  Last time I tried to get it to work it either shut the car off or was swinging around like mad.
Thanks!
Jim
1976 S&H Gran Torino
460/C6/4.33 13.05@105.6
545/C6/3.56 11.52@117.8
460/T56/4.00 cruiser
www.torinocobra.com
www.starskytorino.com
GranTorinoMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 15-December-2007 at 4:10AM
Hey Jim, I had the same problem. The factory tach shorted out my HEI or something and shut the car off. I bypassed it by using a monster tach with a shift light and mounted it in front of the factory tack. I talked to the guy who builds my Aurora HEI box and he said some resistors and diodes probably have to be used to make the old tach work with new ignition systems.
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 15-December-2007 at 8:37AM
Yeah, I have an aftermarket tack that I've been using for years and years, but I so want to have the factory piece working for lots of reasons including the stealth factor.
Jim
www.torinocobra.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 15-December-2007 at 5:27PM
There has to be an MSD tach adapter you can use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2007 at 4:19AM
Hey Jim, I was thinking that a shift light could be built into the rear view mirror for the stealth look. You can put a bank of LED's around it or use a plastic mirror and build them in.  Maybe there's a shop that can change the guts of the factory tach with new components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2007 at 5:44AM
I was going to do what you said, but hide the shiftlight in the drivers side vent. Wink
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2007 at 11:42AM
I'd actually like to hide one in the "Low Fuel Economy" warning light that is on the Sport cluster.  There is plenty of space for 4-6 LED's in there and it should be bright enough to get my attention..
I think I tried the tach adapter when I actually still had the MSD and it didn't work.  Maybe it's time for a call to the Crane tech line..   (I just hate that route)
Thanks!
Jim
www.torinocobra.com
Flipvs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2007 at 8:55AM
Hello Jim,
If you have a sportscluster with Tach, the Tach has to be in series with
the 12v supply of your HEI-ignition. (Or in series with the + lead of the coil, this will work for sure.)
No matter wich of the two wires is used as input. The factory tach has a built-in transformer, and reacts only on current changes.
Current direction is not important.
If you do so, it will work properly !
I've installed in my Torino an electronic ignition, and the tach is working perfect.
Success,
Flip.
Edited by Flipvs - 20-December-2007 at 3:38AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2007 at 2:29PM
Sounds right now that i think about it.. I had the factory tach working in my Elite off an MSD5 box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2007 at 4:54AM
Originally posted by Flipvs Flipvs wrote:
Hello Jim,
Success,
Flip.
Hey Flip, do you still have that Kilometer speedo for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2007 at 7:03AM
Hi,
Yes I still have it.
But first I have to apologize for not answering your last mail.
I changed my settings, and I had to activate my account.
There was a big problem, it did not work!
After a few weeks I stopped trying.
So after a few months I tried again with a new username, and it seemed
the procedure was changed, because it worked  !
Thanks,
Flip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2007 at 1:18PM
Flip, How much do you want for the Speedometer? I can trade you a whole cluster which is still original if you prefer. Can you send some pictures of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2007 at 9:28PM
Hi Jim,
I was wondering if the tach works ?
I upgraded my Torino with a sportscluster, and everything is working,
but not the "low economy" light !
I'm looking for the vacuum-switch or whatever sending-unit it uses.
Can you help me ?
Thanks,
Flip.
Gran Torino'73 Wagon, 351c, Goldglow, sportsmirrors, sportscluster, cold airc., Bi-fuel: Petrol+Propane(LPG), Pertronix ignitor1, 2 Oxygen Sensors and a daily driver !
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 26-December-2007 at 6:05AM
I'm away from the car for the holidays but I'll post if it works.  As for the low fuel economy, I believe any vacuum switch can be made to work.  I was looking at one from a GM product but can't remember the part #..  Perhaps an internet search for Vacuum switch may turn something up.  (I pulled my cluster from a parts car and forgot to get the sensors)
You'd probably need something that triggers around 8psi or vacuum or thereabouts
Jim
www.torinocobra.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 26-December-2007 at 10:21PM
Hi Jim,
The vacuumswitch must trigger around -0.4 PSI, the vacuum range is
from 0 to -0.8 PSI. I have already a vacuummeter installed, but I cannot open
it for building a sensor in it without destroying the case of it ...
I'll have to keep on searching or invent something myself.
Still working on it, but if you find something.....!
Thanks,
Flip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 26-December-2007 at 10:33PM
Hi Chris,
I send you a picture of my cluster with the KPH speedo.
I'm  more interested to trade it for some small Torino things I need and
are hard to get here in Holland.
I also have the (perfect working!) clock  for that cluster!
If you are interested, I'll make  a list of  things I need.
Flip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2007 at 3:51AM
Hey Flip, I'll find what you need, my friend is in the upholstery business and he has many connections.  Did you get those weather seals you needed?
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 27-December-2007 at 6:40AM
I found one that can be adjusted down to 1psi, close but no cigar.  (One thing to remember is that at 1psi vacuum, you are pretty much Wide Open Throttle anyway)
Jim
www.torinocobra.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2007 at 8:46AM
Jim-
A suggestion...I have been tossing the ideaback and forth...as Paul PSquare for pics on his dash setup in his Cougar, really nice, but he used the flat panel, not the torino sport cluster setup.
I plan on honestly yanking out my factory gages.  I have spent too much time fighting the stuff, and honestly, I want something much more precise that that of my 35+ year old gages.
I plan on leaving the spedo, but replacing everything else.  My biggest obstical has been the wanton destruction of a cluster housing...I have a couple 72 clusters, and they arn't exactly growing on trees.
I have thought basically by removing all the small gages, and leaving the factory tach and spedo alone, and attaching the gages into the small pod openings, it works pretty good.
I plan on autometer stuff, but being as braoke as I am, I have picked up a couple EQUIS units from a local parts store...still need to get around to installing the things, just need to get over my hesitation and install them.
I had a seperate post a while back about LEDs in my '72 sport cluster-
As far as your tach, if you don't mind a bit of fab work, get a piece of 3/16" sheetmetal or aluminum, and mount the aftermarket gages to it, using the ford sport cluster trim piece as a template for the openings.
Hiding the LEDs for a shift light in the fuel eco light is a good idea, and if feeling creative, you could always get a new piece of colored plastice and paint on new letters on the back so it's only visable with the lights on {I was thinking of something like "SHIFT, DAMN IT!!"}, as a suggestion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2007 at 4:46PM
Someone on 460ford.com with a yellow Ranchero (Fomoco8?) did what Andy did with all AutoMeter gauges in the stock cluster.
I used the flat panel from a 77-79 Cougar/LTDII/Ranchero, it was much easier to work with.
In all honesty, I wish I just kept the stocky gauges, I blew way too much on these, and I'm not all that happy with the result.
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2007 at 4:00AM
I was planning on using my existing 2 1/16" autometer gauges (they are currently mounted below the ashtray) plus a fuel pressure in the stock sport cluster just as you have done.  What I may add to the equasion is getting them silk screened by a company we do lots of business with to match the speedo and tach font/design.. I have verified the fit of the gauges, I just want them to look right.  I may have to do some lexan work though, as the hole for the clock adjuster bothers me..
One more little bit I may try to do is get the speedo recalibrated for 160mph (and renumbered).  I know it can be done relitively easily, I just have to find the place that did my old speedo to match my gears..
Jim
www.torinocobra.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2008 at 10:32AM
Hi Chris,
I still haven't found weather seals for the 4-door model. (wagon)
Maybe you can help me find those seals?
I'm sure we'll find  a way  to  pay / trade the seals / speedo /clock !
Flip.
Edited by Flipvs - 06-January-2008 at 10:33AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 07-January-2008 at 4:57AM
Hey Flip, I talked to my buddy and he said he can match any weather seals, all he needs is a cross section scan so he can see what shape it is. Take a piece of the old seal, slice a piece off the end, put it on a white paper, scan it and send it to me.  csmarko@telus.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 07-January-2008 at 5:15AM
Flip there was that guy on eBay selling 2 door Torino sets, He said he could match any set as long has he had a sample. He was interested in doing 4door/wagon parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flipvs Quote  Post ReplyReply Direct Link To This Post Posted: 07-January-2008 at 11:19AM
Hi Paul, Chris,
Thanks for the reply, I'll try to take a sample, but there are some
pieces at the end of the seals (front doors)  in a very different shape.
I will try to take some pictures of the seals.
Thanks,
Flip.
This page was generated in 0.182 seconds.
