Fender insulation |
ssregal39 ![]() New Member ![]() Joined: 04-August-2013 Location: Norfolk VA Status: Offline Points: 25 |
![]() ![]() ![]() ![]() ![]() Posted: 24-October-2020 at 8:03AM |
Anyone have a source/solution for the pieces of insulation that go in the rear of the fenders?
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 13160 |
not quite sure what you're referring to? i don't recall any fenders having insulation...
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Online Points: 1061 |
I'm not familiar with what the 70's cars had, but I thought he meant the insulation material that is common in 90's Fords. I reconstructed a 93 Explorer and had a wind noise from the LF door hinge area. I discovered that looking into the fender from the hinge area, there is a part that is shaped like that space which is barely attached in the fender. It's about an inch thick and I think they were stuck on the fenders when new with the same body seam sealer type product. I dug that part out and back to fit the opening, RTV'd it in place, and the wind noise was greatly reduced. I then found a noise from the mirror, a different used one that didn't fit the door as well. Some RTV along that gap, and it made the truck much quieter. So it's probably a good thing to have that in all front fenders.
73 Ranchero GT 351C-4V 3.70 gears, to build a keeper 73 Ranchero Sport "72 front end", floor shift/console, planning EFI 351-3V &4R70W 92 Lincoln Mark VII SE, OBDII 347/4R70W |
there's insulation sheets at the rear of the fenders near the door jam. Roughly 24" high and 8" wide. Probably for road noise? Mine are disintegrated.
Bingo, they did have those. Are either of your old ones shaped properly? Ideally you have an old one to use as a pattern at least. I'd find a later model car and see what the material looks like. I doubt a newer car will have a perfect fit part, but making one may not be that hard to do.
oh ok. 73-76 torinos had a plastic baffle in there i think that's what you're referring to? i have some but i'm thinking the 77-79 fenders are a different shape so probably fit different...
yep thats it. I wonder what material would be suitable to cut my own.
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5185 |
not so much insulation but a block-off / filler piece, they're molded plastic
Those will help a lot with wind noise, but put some insulation onto them too.
those are thin pieces of polyethylene plastic
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 3898 |
My Thunderbirds both had a plastic shield with a wad of fiberglass behind it (between it and the "Bigfoot" part. Cougar fenders i pulled out of a Junkyard also had them.
hogfiddles ![]() Senior Member ![]() ![]() Joined: 19-September-2016 Location: Central NY Status: Offline Points: 729 |
do you need for a ‘73? Which side? I’ll see what I have.... I’m turning my ‘73 into a ‘72
Dave Fox
1969 Torino GT - M code numerous mid-80's Yamaha XJ-Series (10 trophies and counting) |
![]() I have light blue car and swapped on some cream fenders and hood. All that is coming off this winter to rust bust and paint everything fresh so wanted to replace these guys.
Very good, that will make a great template to replicate them. I'd like to see the results if you get time to post any pictures. If you make a paper board template of that, I'd like to have one also. My 73 I don't recall installing that kind of filler piece into the 72 front end when I swapped it in 1989. I'd want to add that to any car that is missing them.
That’s because, as I understand it,the ‘72 fenders have a different contour to the inside. I guess I probably should actually try putting my ‘73 shields into my ‘72 fenders to see first-Hand if there really is a difference. Dfox
They should be really close, they are the same at the back except for the mounting changes made for 1973. That insulation or cover part should swap with minimal alterations.
Lizer ![]() Member ![]() Joined: 04-January-2020 Location: SW Michigan Status: Offline Points: 58 |
There's a guy on the LTDII facebook group who makes fiberglass and carbon fiber pieces, he could certainly recreate that part if he had a good template from which to make a mold.
67 Mustang (5.0) 69 Mach 1 428 SCJ Drag Pack |
rancheromac ![]() Member ![]() Joined: 12-August-2013 Location: IOWA Status: Offline Points: 57 |
me to! it fits to back of fender to sound deaden and make sure water and debris dont hit the front of inner door
Tweet
