  New Posts New Posts RSS Feed - Flare Nut for Brake Line
texanrebel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Topic: Flare Nut for Brake Line
    Posted: 16-December-2020 at 3:35AM
Had to cutoff old flare nut on passenger side front brake line - needing to double flare the line now and add new nut. Anyone have a preferred brand nut to install? I've read some on threading issues with some made overseas - thanks for insight / words of wisdom
1972 Montego GT
1977 Mercury Monarch
1988 Ford Thunderbird Turbo Coupe
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2020 at 5:29AM
I'd go to NAPA or a similar hydraulic hose company for a line fitting. Those places are more likely to carry high quality fittings etc. If that's the brake line which the hose connects to on the frame, how bad is the line? Is it good enough to do a new flare and keep it?
Nicopp brake line is very flexible and easy to shape to fit original routing. I used it to replace a LF line on my friend's 90 Lincoln, so it was really quick and easy for a short length. I would consider it a good choice for longer lines too, but I haven't done that yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2020 at 6:21AM
Excellent suggestion, wasn't even considering that. Thanks Don!
1972 Montego GT
