  New Posts New Posts RSS Feed - Floor Pan Compatibility.
351Fastback View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 351Fastback Quote  Post ReplyReply Direct Link To This Post Topic: Floor Pan Compatibility.
    Posted: 03-June-2015 at 2:21AM
So once I got my car jacked up and was able to crawl underneath it, I realized the rust was worse than I thought.
There's so much fiberglass in those floorpans that I'd believe someone if they told me they drove it here from Cuba. 😂
Luckily the rust is confined to the floor and trunk. It's solid everywhere else. I'll be good to go after a pan swap.
Tbe big question is, which pans will fit (or closly fit with mild mods) my 73 GTS coupe?
There are no local Torino's for sale at the moment, but I found a wrecked '72 Montego sedan.
Will the floor pans and trunk pan fit?
Edited by 351Fastback - 03-June-2015 at 2:22AM
1973 GTS 351c Auto
1963 Corvair Monza 4-speed
1964 D100 Shortbed 318 Auto
1968 Ranchero 302 Auto
2005 Mini Cooper S
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2015 at 2:30AM
yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2015 at 2:33AM
It sure would be a good donor. Check the cowl areas as well.
1972 GTSquire Wagon
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2015 at 6:37AM
72-76 TORINO AND MONTEGO
74-76 COUGAR
72-76 MARK SERIES LINCOLN
77-79 THUNDERBIRD AND COUGAR SHOULD ALSO WORK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2015 at 8:39AM
72-79 mark series Lincoln, 72-76 t-bird, Any midsize wagon, 4-door, or ranchero 72-79 will work, but they all have a 4" longer wheelbase and will need to be trimmed in the rear seat area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 351Fastback Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2015 at 12:53PM
Thank you guys! That's very helpful, I've seen some Lincolns floating around for cheap too.
Has anyone ever used Classic 2 Current pans?
http://www.c2cfabrication.com/collections/all/ford+torino+1973
It would be super convenient to have these shipped to my door for a few hundred dollars.
1973 GTS 351c Auto
2005 Mini Cooper S
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2015 at 1:22PM
i bought a pair of the rear pans like that (probably made by them and sold by others) they are NOT stamped pans like original, the curved corners are just sheared and bent in a brake! i think i paid $79 ea. i could have made them the same way for about $10 but live and learn!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2015 at 2:02PM
posted my reply on your other thread
