  New Posts New Posts RSS Feed - Ford 8inch Torque Specs
roknxj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roknxj Quote  Post ReplyReply Direct Link To This Post Topic: Ford 8inch Torque Specs
    Posted: 30-July-2018 at 5:21AM
Can anyone tell me what the torque specs are for a Ford 8 inch axle? From axle / wheel bearing bolts to the 3rd member. I have some specs but not all. Here is the work i have done so far.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2018 at 3:30PM
Give me a day and I should be able to get them for you
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 31-July-2018 at 12:53PM
The differential bearing cap bolts are 55-70 ft-lbs for a 8" rear differential.
The differential bearing cap bolts are 70-85 ft-lbs for a 9" rear differential.
All below specs are for 8" and 9" differentials.
Differential bearing adjusting lock nut bolts: 12-25 ft-lbs
Carrier to housing stud nuts: 25-40 ft-lbs
Pinion retainer to carrier bolts: 30 -45 ft-lbs
Ring gear attaching bolts (use Loctite): 70-85 ft lbs
Oil Filler Plug: 25-50 ft-lbs
Rear Axle Shaft Bearing Retainer bolt nuts: 20-40 ft-lbs (Torino, Montego, Comet, Maverick, Mustang and Cougar).
Universal joint to Pinion Companion Flange Bolt Nuts (except civular flange): 12 -15 ft-lbs
Circular Flange: 70-90 ft-lbs
Edited by 72FordGTS - 31-July-2018 at 12:53PM
