Ford Parts guys need help. |
Post Reply
| Author | |||
madmaxtorino
Zombie Killing Training Instructor Joined: 04-August-2010 Location: Lawrenceburg Tn Status: Offline Points: 972 |
Quote Reply
Topic: Ford Parts guys need help.Posted: 11-September-2014 at 3:57PM |
Need to know what these brake valves fit. D5MY-2B257-A and D5MA-2B328-A2B
Allan
Eliteman76
Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 5450 |
Quote Reply
Posted: 11-September-2014 at 4:05PM |
I posted on Facebook to Gary, he works for Ford.
Ramair351, Pete, also can help. |
Andrew:GTS.ORG admin, '72 Q code 5 speed RestomodPondering: #99Problems |
dave302
Joined: 08-October-2009 Location: usa Status: Offline Points: 3171 |
Quote Reply
Posted: 12-September-2014 at 12:44AM |
The D5MY-2B257-A is for a 1975 mercury Marquis with rear disc brakes.
It is a ford and mercury pressuse differential valve. It is the same exact valve as the part number D6AZ-2B257-E .
Edited by dave302 - 12-September-2014 at 1:30AM |
dave302
Quote Reply
Posted: 12-September-2014 at 1:48AM |
I cannot find any information at all on the D5MA-2B328-A2B part number. Maybe one of the other members will know.
But many times there is the service part number and the engineering part number. The service part number might be D5MY-2B257-A and the engineering part number might be D5MA-2B328-A2B? Are these two different valves that you are asking about? Or are both of those part numbers printed on the same valve? I have found an application for a D5MA-2B328-AB part number (notice that there is no number 2 in the part number). It is a combination proportioning valve and differential valve. It measures 6 inches long by 3 inches high, it is usually used for a drum brake to disc brake conversion on ford and mercury vehicles. The part number is from 1975.
Edited by dave302 - 12-September-2014 at 1:52AM |
Torinogts73c
Joined: 14-February-2004 Location: Tucson Arizona Status: Offline Points: 1039 |
Quote Reply
Posted: 12-September-2014 at 3:51AM |
Edited by Torinogts73c - 12-September-2014 at 3:54AM |
"Never complain Never explain" Henry Ford |
madmaxtorino
Quote Reply
Posted: 12-September-2014 at 1:56PM |
Thanks for the answers! I bought one nos and wanted to confirm its application. gonna use it on my torino to change to 4 wheel disc. Seller has some more of these nos if anyone is interested. They are $ 175.
Allan
dave302
Quote Reply
Posted: 12-September-2014 at 2:06PM |
Your Welcome.
GranTorinoSport
Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2290 |
Quote Reply
Posted: 17-September-2014 at 4:17AM |
What rear disc style are you intending to set up? |
Webmaster |
madmaxtorino
Quote Reply
Posted: 17-September-2014 at 2:10PM |
Allan
GranTorinoSport
Quote Reply
Posted: 17-September-2014 at 3:23PM |
Mark V, I presume?
Webmaster |
madmaxtorino
Quote Reply
Posted: 17-September-2014 at 3:44PM |
yea
Allan
Billy C
Joined: 10-February-2010 Location: Pittsburgh, PA Status: Offline Points: 953 |
Quote Reply
Posted: 18-September-2014 at 8:45AM |
I'm working at the 79 Lincoln Mark brake swap too. The biggest setback was the bolt pattern but I solved that by just going with different wheels. Luckily I had a donor car so pulling everything off was a breeze. I think I'll be pawning off all my 5 on 4.5 stuff one of these days.
-Billy Conturo
GranTorinoSport
Quote Reply
Posted: 18-September-2014 at 9:01AM |
If a person was good with 5x5 bolt pattern, is the rest pretty straight forward?
Webmaster |
Billy C
Quote Reply
Posted: 18-September-2014 at 5:51PM |
ya... mostly bolt on. That proportioning valve shown above is going to be part of the swap too (if it is the same one). Lot more cool stuff with the swap, but that's for another post
I should check my Lincoln proportioning valve part numbers and see if they are the same...
-Billy Conturo
Montego01
Joined: 16-December-2012 Location: Largo Status: Offline Points: 565 |
Quote Reply
Posted: 18-September-2014 at 10:50PM |
I bought that valve and found as mentioned the only difference is the size of the line for the rear brakes
Post Reply
| Tweet |
