  New Posts New Posts RSS Feed - FORD POINTS
FORD POINTS
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Topic: FORD POINTS
    Posted: 18-April-2017 at 6:02PM
im trying to find out whats difference between the ford pints dp5 and dp6.the dp6 are for the 289 hipo and the dp5 is for the 429 cj/boss.i have more dp6 then i need but only one set of dp5.i think thay will work in ether set up.what do you think.thanks....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2017 at 5:31PM
the difference might be the spring tension, the Hi-Po 289 would have more spring to run more rpm
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2017 at 2:48PM
thats what i was thinking but just trying to confirm.im seeing people on ebay trying to sell dp5 for the hipo 289 motors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2017 at 3:18PM
i'm not sure what you are referring to on the #'s but as far as points go... i've always ran "blue streak" by standard ignition brand they cost more than the el-cheapo one's but far superior as any i've ever used back in the day, not sure if they still make them??
they are in a blue box and the points look copper... like this:
Standard Motor Products Blue Streak Points Only MC-DR2240X
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2017 at 4:12PM
DP5 is for standard single point distributors.
DP6 is for hi-po dual point distributors.
They are dimensionally the same, but the DP6 has higher spring tension, and doesn't last as long.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
