  New Posts New Posts RSS Feed - Ford Torino 1971 speedometer
kosaszabolcs View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote kosaszabolcs Quote  Post ReplyReply Direct Link To This Post Topic: Ford Torino 1971 speedometer
    Posted: 21-May-2020 at 11:25AM
Hello guys
What might be causing the erratic shaking of the speedometer “needle” in the instrument cluster/dashboard?!.
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2020 at 3:22PM
could be a couple of things... check the cable for and kinked or damaged spots, more than likely it dry inside! you can pull the inner cable out from one end (bottom i think?) if someone used grease it may be old and thick will need cleaned off and relubed if there's no grease you can lube it with dry graphite powder Wink also check the plastic gear on the end for worn or missing teeth!
