  New Posts New Posts RSS Feed - john's 74 s&h clone build thread
 Post Reply Post Reply Page  <1234 74>
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:04PM
passenger side header in (no actual mods to the header itself)Big smileBig smile
Edited by californiajohnny - 16-March-2014 at 4:02PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:13PM
driver side header did require a little bit more modification (all in all not bad, as far as headers go) grinding on the top edge of the motor mount by the bolts
Edited by californiajohnny - 15-December-2014 at 5:58PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:16PM
and a small denting of the header tube by the rear bolt of the motor mount
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:18PM
and a small dent by the front bolt as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:20PM
this is the dents made to the bottom of the header tube which are totally unnoticable when installed
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:23PM
drivers side header inApprove
Edited by californiajohnny - 15-December-2014 at 5:59PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:27PM
great clearance around the steering box area
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:28PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2013 at 5:32PM
tomorrow i'll call the ceramic coating place and off the headers go to get coated!! this has not been cheap, but stock ford manifolds are just plain FUGLY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2013 at 3:29PM
i dropped the headers and NOS hood hinges off at the ceramic coaters should be a week to 10 days (i can't wait!) till they are done. stay tuned... pics to follow then Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-December-2013 at 5:22PM
i decided to box my lower rear control arms; one done...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-December-2013 at 5:24PM
back in and bolted up. one more to go...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2013 at 3:09PM
other side boxed, pressing bushings back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2013 at 3:10PM
bushings back in
Edited by californiajohnny - 15-December-2014 at 6:01PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2013 at 3:18PM
putting the arm back in. both sides done. time: about 1 1/2 hrs total,cost: a few dollars for welding wire and argon gas (metal was stuff that i had- i save all useable pieces of metal, just for projects like this!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2013 at 2:06PM
got my new stainless mufflers today! i decided i might as well just do all of the new exhaust system now (when i get the headers back) switching from 2" to 2 1/2" it should flow a lot better, and sound totally awesome Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2013 at 6:56PM
brief holiday update: i've been working on my stepbrother's f150 - bed is coming along good (custom body work and paint) replaced the drivers door match paint and graphics (simple enough, right?) got paint custom matched at the paint shop, one color matches perfect, the other color, not even close!!! so i got ahold of the guy that originally painted the truck about 15 years ago, he told me that the purple paint was something custom that he mixed, when he worked at a body shop. step brother claims he has some of that actual paint left (we looked a couple of weeks ago, no luck finding it) option #1 find the actual paint, or option #2 repaint the entire bottom of the whole truck!!! step brother is in alaska for xmas, called him, he says go look in his garage again (it's a mess just like mine Wacko ) after about only an hour, i found a quart and a half of that paint StarBeer now all i have to do is find out what reducer i need for that paint. oh, and during all this, one of the light ballast in the paint booth decided to crap out, trip to home depot 20 miles north (they are out of that one) home depot 25 miles south (they are out as well) Angry so today i check one of the local hardware stores, i find the one down on the bottom shelf (they didn't think they had one) StarBeer (who's the man?)!!! my step brother thinks he is going to be helping on the torino, with disassembly and removing the body, etc. well after all of this (on his truck) i think i'll have him doing some block sanding primer, in addition to just helping! (he just don't know it yet LOL) here's a couple of pics as to the extent of what is involved
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2013 at 6:58PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2013 at 6:59PM
new bed so far...
Edited by californiajohnny - 15-December-2014 at 6:02PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2013 at 7:00PM
old door...
Edited by californiajohnny - 15-December-2014 at 6:03PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2013 at 7:01PM
new door so far...
Edited by californiajohnny - 15-December-2014 at 6:04PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-December-2013 at 6:12PM
i got some woodgrain vinyl (high gloss) today, so i decided to rewoodgrain my dash bezel
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 8:05PM
picked up (3) 2 1/2" 10' exhaust tubing saturday, got my 3"  polished stainless exhaust tips today, now all i need is my headers back from the ceramic coaters, then i can start bending and welding up my new exhaust system. so in the mean time i decided to woodgrain the right side dash panel, what a P. I. T. A.  that piece is to get off of the car!!! Angry but the end result came out great!
Edited by californiajohnny - 11-April-2015 at 7:26AM
Grantorinosport351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 8:29PM
That looks phenomenal!
~Bryan
72 gts h-code (formal roof)
67falcon
04 f250 ''the great white''
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 8:32PM
THANKS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 9:25PM
BTW, the truck is lookin great, keep us updated.
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-December-2013 at 9:37PM
yeah, i got the right purple on it saturday and cleared and cut and buffed sunday night, looks like a million bucks, i'm off work tomorrow, so i plan to match and pinstripe the door, then i can sand and paint the bed, next, then get the truck back to one piece, so he can take it home and i'll have more room in my shop to start disassemble the torino Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2013 at 7:50PM
new years (15 minutes to go) sneek in a little work on the torino, woodgrained  scanner bezel to match the dash
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2013 at 7:52PM
installed (in the console)
Edited by californiajohnny - 15-December-2014 at 6:05PM
This page was generated in 0.176 seconds.
