john's 74 s&h clone build thread |
Post Reply | Page <1 4748495051 74> |
Regul8r
That works. |
yeah, if joe has an original to trace that might be better, i had nothing! so mine may still need some revamping as i haven't fit it with the seat or sail panels yet
started deconstructing the rear panels:
cut out replacement cardboard sections (warped water damaged) out of luan: metal upper part reriveted onto the luan: |
ilyes
Making tons of progress, I like that. It's nice to see people committed to get things done, and done right.
Regul8r
John tell me about the "luan"
What is it exactly? |
fordpower
I tried that on pinto it was a little to thick. Material would not wrap around right.I used what was called 1/4 in
it's 1/8" luan, luan is basically a close relative of mahogany. most people would refer to it as interior door skin (house doors) it's really only good for flat panels, i prefer to use it for flat panels vs hardboard as it don't warp (from moisture) like the hardboard can, my upholstery guy will argue with me about it as he prefers to use the hardboard, it's cheaper and easier for him to work with.
my upholstery guy only had enough black vinyl left to do the rear panels, he's getting another roll in on monday, i really wanted the larger piece to cover the package tray so i could finish that and install the 6 x 9's but the good news is that piece to do both panels was only $10 |
Regul8r
John, I went to Jo-Ann Fabrics for the materials.
Marine grade vinyl on the rolls, available in colors and will be easy to repair/match in the future. |
75GranMan
Regul8r
here was mine from back in July...
Did my package/speaker tray tonight...
Clearing more stuff out of the garage I have been collecting over the years!! The old Speaker/Package tray fell apart in pieces crumbling as I handled it. Made it like a puzzle to trace the pattern on 1/4" MDF board. 6x9 speaker holes cut using the supplied template. Cut the White Marine vinyl, sprayed with the adhesive and pulled/wrapped it tight. Installed along with the speakers. Came out decent for a 1st time doing it!! MORE FIRSTS!! |
john: nice counter tops dude! (you must have done that when the wife was gone)
Edited by californiajohnny - 20-December-2014 at 5:33PM |
worked on the drivers side rear panel tonight, after removing the old vinyl and hardboard, i methodically bent the "riveted " prongs back straight:
then after marking and drilling the holes (5/16) in the new luan panel, i painstakingly bent each of the 4 tabs (per hole--about 20 holes) towards the panel to act as a rivet: then after all tabs were bent, i gave each hole a firm whack with a hammer to firmly tighten the two parts together: Edited by californiajohnny - 20-December-2014 at 5:34PM |
lay out the trim and armrest base:
and padding to form the recess of the trim: |
TV 2M8O
WOW JOHN, those are looking great!
BTW... I got my package tray traced out yesterday and will take it to work and scan it into the computer so I can clean some of the jagged lines up a bit and have it ready for when it comes time to do mine. FWIW, my OEM tray had a piece of open mesh (screen-type) material glued to the underside of the tray followed by a layer of jute THAT WAS NOT CUT OUT IN THE SPEAKER AREAS. My car came with a single speaker AM radio so it never was an issue, but I wonder how that jute between the speaker and tray would have effected the sound??
i'm sure it would really "muffle" it, a thin layer of just fabric may be ok, but the jute insulation should cut down the sound quite a bit
Regul8r
John THAT is awesome work!!
got one panel finished (still have to woodgrain the chrome trim yet)
TV 2M8O
DEEaaaaaaaaaammmmmmmmmmmmnnnnnnnnnn... NOW THAT IS NICE!!!
75GranMan
John, looks great, your a man of many talents!
since it wasn't raining at the moment, i decided to back the car out and change that damn light ballast that quit working about a month ago (damn i can see in there again ) here's a better pic of the grill and front bumper: |
Regul8r
John that bumper and grill looks better than I would have thought!
LOOKS GOOD!!! |
carl: yep!
well whadoyaknow-- 74 pages of build thread for a 74 torino finished the other rear panel: (well almost, i ran out of staples in my paper stapler) Edited by californiajohnny - 22-December-2014 at 6:42PM |
got home early enough to stop buy my upholstery guy's place and get some more black vinyl, to do the package tray, and i got it done!
Paul100ca
Senior Member Joined: 21-November-2014 Location: Ontario, Canada Status: Offline Points: 315 |
You are really going to town on your build....
i've been needing to get the side windows tinted so i can put all the panels, trim, etc. on , they need the panels off to have room to do it, but they aren't open on saturdays and they're closed all days of these holidays, but as luck would have it,... i just happen to have tomorrow off, too( 5 days off) so 9:00am tomorrow road trip!!! and hoodless! if it's raining i may have to remove the air filter (paper filter and rain--not the best of friends)
Edited by californiajohnny - 25-December-2014 at 8:26PM |
got the 6 x 9's in, package tray in!
laying in the trunk to hook up the speakers: all done! can't wait to hear these new speakers..turn on the stereo...WTF!!! NO SOUND! well since the tinting place is nextdoor to a stereo store, looks like i'll be buying a NEW stereo too Edited by californiajohnny - 23-December-2014 at 7:10PM |
Grantorinosport351
looks good john!...so uh...you know christmas is in a couple days...and ive been pretty good this year....you can just hand over the keys and title when you're ready
~Bryan
^^^yeah, it's christmas, not april fools!
Chris E
Member Joined: 03-August-2013 Location: florida Status: Offline Points: 87 |
car looks great john!!!!! I can't think of a better christmas present than having your car finished. Hope you have a great one. Merry Christmas!!!!!!!
Chris E
windows tinted! (stereo place out of business)
BTW, what else would santa drive on christmas eve? a red & white torino of coarse!!! |
