Bushings for REAR sway bar ref D2OZ-5B486-B |
ViperGTS
New Member Joined: 14-November-2013 Location: FRANCE Status: Offline Points: 2 |
Posted: 14-November-2013 at 10:33AM |
Bushings for REAR sway bar ref D2OZ-5B486-B (Torino 73/76 or Tbird 1973 or LTD 77) The Ford rear sway bar is the same on Torino 73/76 or Tbird 73 or LTD 77 and the bushings that goes into the eye on the end of the REAR sway bar ref D2OZ-5B486-B is something impossible to find. It's possible to replace them with small modification (cut the length and use a little bigger axe) with this one : 77 04 001 371 for Renault. I know that Renault bushings are something rare at the US, but : The bushing Renault was using on R12/R15/R17 AND DACIA Analogous \ Similar Parts of RENAULT 7704001371 A.B.S 270293 MALO 277 MOOG RE-SB-1332 RTS 017-00402 You can try RESB1332 on www.rockauto.com ..................... |
what i used for my 74 gran torino factory rear sway bar bushings in urethane was energy suspension # 8141r in the sway bar eye, and for the link to frame bracket was energy suspension # 8101r
TV 2M8O
John, Looking thru the Energy Suspension catalog, I'm going to assume there is a "9-" in front of those part numbers (universal application)? What part number did you use for the actual sway bar bushing? My rear bar measures about .687" od... Thanks!
joe, yes there was a "9" my bad the part #'s are energy suspension 9-8141 universal shock bushings (for sway bar) energy suspension 9-8101 universal shock tower grommets (for sway bar link to frame bracket) for the sway bar mount on the differential i used prothane # 19-1116
energy suspension: 9-8141r (red) 9-8141g (black) 9-8101r (red) 9-8101g (black) prothane: 19-1116 (red) 19-1116bl (black) Edited by californiajohnny - 08-February-2015 at 3:11PM |
TV 2M8O
John,
Can you post a few pics showing these bushings installed/mocked up? Won't be long until I'll begin reassembly of the rear end and would like to have all my ducks in a row.... THANKS
Thanks(2)
TV 2M8O
THANKS JOHN
1973torino429
Member Joined: 17-November-2015 Location: SW Indiana Status: Offline Points: 73 |
John, I bought the urethane pieces that were recommended and have misplaced the outer and inner sleeves, any other options???
1973 Gran Torino Sport 429
1973 Gran Torino Sport 351 4V 1972 Gran Torino Sport 351 CJ 1972 Gran Torino Sport 351 CJ 1972 Mach 1 351 CJ 1989 Mustang LX 5.0 1988 Mustang LX 5.0 1996 Mustang Cobra |
IDK... maybe try to find a piece of metal tubing the correct size.....
what size are the bolts?
front sway bar link kits come with a generous stub of sleeve ...
yes the inner sleeve shouldn't be an issue to find but i think he's more concerned with the outer shell that's pressed into the bar....
yeah that's gonna be tough
1973torino429
Yeah, I have the inner sleeve issue taken care of, the outer is gonna be the problem , emt pipe is close but not good enough, I'll figure something out....
Anderslober
Senior Member Joined: 30-July-2019 Location: Denmark Status: Offline Points: 764 |
How did you press in the bushing in the sway bar eye?
if you're asking how i did it using the poly ones ... i greased the bushing and used a socket just smaller the the outer dia. and carefully pressed it in without the inner sleeve so it can squish to get through the other shell once its in place then you can slide or press the inner sleeve in
Anderslober
Wont the sway bar ‘slide’ around on the bushing?…
the energysuspesion bushing has a lip on each end you leave the original other sleeve in the bar!
Anderslober
I got a good look at what the rear wåsway bar link actually looks like today. There is an outer metal sleeve which is part of the sway bar. The Bushing is pressed through this sleeve and then the inner bushing sleeve is pushed in.
Great! Now I know.
