  New Posts New Posts RSS Feed - 4bbl swap questions
4bbl swap questions
Roehm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roehm Quote  Post ReplyReply Direct Link To This Post Topic: 4bbl swap questions
    Posted: 24-September-2007 at 8:16AM
Alright fellas I am swapping the 351W that is in my car from 2bbl to 4bbl. I know the car originally had a 351w 2bbl. Am I going to need to get a different throttle linkage and kick down for the car. I am sure I will need to but any suggestions where I should get one. BTW the car is a 78' Cougar XR7.
Thanks,
Dan
P.S. I am still working on getting pics yo.
78' Mercury Cougar XR-7 351W/C6
PatsPOS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatsPOS Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2007 at 4:36PM
Well, that would depend mostly on the intake you plan on getting.  If the carb pad is at stock height, or a little higher, you shouldn't have any problems using your current throttle cable and kickdown.  However, if you're planning a hi-rise intake (which you really don't need if you plan on leaving the rest of the engine stock, or close to it), you'll likely need a new throttle cable, and plan on changing your kickdown rod to a cable as well.
I modified a kickdown rod when I put a Weiand Stealth intake on my 460, and while it seems to work well enough, it ain't pretty.  Someday I plan on replacing it with a cable.  Lokar is the name of choice when it comes to aftermarket cables...first place I would call is Summit Racing, but lots of performance-related places should be able to help.
Pat
'75 460 Gran Torino Sport (14.04 @ 97 MPH)
'91 Crown Vic (18.09 @ 75 MPH)
'89 300 F-150 (18.37 @ 73 MPH)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2007 at 1:38AM
If you get a performer intake and edelbrock carb, most likely no, it'll be fine. The kickdown rod is easy enough to modify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roehm Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2007 at 3:52AM
I am going to use a stock cast iron intake manifold so I guess everything should work out ok. However I do plan on going to a weiand stealth a little later down the road. Thanks guys I appreciate the info.
Peace,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2007 at 5:13AM
A stealth is a little too high end for a stock 351W, IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roehm Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2007 at 2:29PM
There will be other parts added before that...such as cam and headers, maybe some other stuff. Ohh btw I looked at some pics of your cougar a while ago Psquare75 and my cougar looks exactly like yours, interior and all. Your is really quiet nice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2007 at 1:24AM
Ah cool, Thanks. I finally took it out last night a little bit after parking it for 4 months... got rid of detonation I was having etc. I won't say I "fear" the car.. more like "respect" the car. farther I press the gas, the harder the car pulls.. I still haven't REALLY tried a WOT run, nor have I just stuff it from a standstill. I think that will just result in a bunch of tire smoke. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roehm Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2007 at 7:36AM
With that drive train I can see what you mean.
This page was generated in 0.140 seconds.
