  New Posts New Posts RSS Feed - Tach no worky-worky
Tach no worky-worky
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Topic: Tach no worky-worky
    Posted: 01-August-2014 at 8:29AM
So, I am assuming many have crossed this path before, so the answer is probably obvious. I did some searching and found some comments from Andy (Eliteman76) from some time ago.
my 75 Sport is now running and driving. The ignition is new - removed the brain box, distributor and coil and replaced with a Mallory Unilite distributor and MSD Blaster coil. It works obviously but the tach no longer works. I believe (but need to verify) I tapped the coil + and ignition module + correctly off factory wiring to the new coil + and distributor + respectively.
However the tach no longer works. I thought for sure I tapped the correct wires because I was trying to ensure I was using the resistance wire for the coil as we should always try and do unless we intend to wire up an external ballast resistor. I replaced the tach with another from another cluster. The original and replacement tachs were known good units.
Is it something about the coil and/or distributor causing this? They are pretty vanilla parts.
Do I just have it wired up wrong somehow? That is a real possibility. I am leaving for a week, hence no ability to troubleshoot for a while (I am driving the car to Spokane for a week), but can get on it when I get back.
Other thought - Should I just run a new coil power wire from my ignition switched relay source I created and go through an external ballast resistor and include the coil in the run? It almost makes more sense to just bypass as much of the factory wiring as possible, as old and crappy as it is.
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2014 at 12:02PM
scott, you have a two wire tach? (i think the later ones were three wire tachs) the two wire tachs are basically from the ignition into the tach and out of the tach to the + side of the coil ( basically it's running inline through the power wire to the coil) there was some discussion a few months back about the tach and using a msd box here somewhere
smhj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smhj Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2014 at 12:28PM
I think with the 2 wire tac you have to get the adopter from MSD.
73MONTEGO
bata747-8 View Drop Down
Honorary Spam Bot / Zombie Account
Post Options Post Options   Thanks (0) Thanks(0)   Quote bata747-8 Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2014 at 7:23PM
I do have the two wire tach, but I am not using an MSD box, the Mallory Unilite has control internal to the distributor.
However, if that is the case, no wonder it doesn't work.
Darn, that sucks!
Forum Test Account
(formerly a spam bot account)
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2014 at 7:57PM
All of the information that you need should be in the thread below.
In this next thread some of the members had talked about how to wire an MSD ignition into a factory original type of Tachometer. I know that you have a mallory unilite ignition, but there are some good answers and wire routing explanations in this thread.
This next thread has some good information about how to install a ballast resistor.
Edited by dave302 - 02-August-2014 at 2:49AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2014 at 3:18AM
These next two threads are about installing and wiring a Crane electronic ignition, with an MSD Distributor, that is connected to a factory original (and an aftermarket) tachometer.
I know that you have a Mallory Unilite Electronic Ignition, but it may give you some good ideas and answers that you might need.
Edited by dave302 - 02-August-2014 at 3:22AM
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2014 at 10:38AM
Dave thank you very much for the links. You are five thousand times better than the search engine here!
It almost seems like sending my tach ( and other gauges) into Rocketman for modification may be best.
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2014 at 11:36AM
Your Welcome.
carguy47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carguy47 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2014 at 1:29PM
Dave, I thought I remember seeing someone sending their tach out to be updated?
I am running into the same issues with the tach not working with a 1-wire HEI. I thought about having the original reworked and updated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2014 at 3:02PM
Originally posted by GranTorinoSport GranTorinoSport wrote:
It almost seems like sending my tach (and other gauges) into rocketman for modification may be best.
Unfortunately I was very busy today, so I was not able to read most of the other threads about this subject fully in depth. So i do not know if that is your only option to get the tach to work.
But i can tell you that there is some more information about the wiring of a mallory unilite ignition into the factory type of tachometer, in the following thread. I am not sure if the following information was talked about already. This member had also installed a Ballast Resistor. Click Here to see it.
Originally posted by carguy47 carguy47 wrote:
Dave, I thought remember someone sending their tach out to be updated?
Unfortunately, I do not have the extra time right now to find that particular thread (Sorry). But i will try to find it for you tomorrow, (if i am able to). But i cannot guarantee you that i will be able to find it.
Edited by dave302 - 04-August-2014 at 4:26AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2014 at 4:28PM
are you referring to the gm style 1 wire HEI? if so, that's what i'm running on my car, and i have the factory two wire tach hooked up and working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bata747-8 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2014 at 5:06PM
There is another (supposedly) reputable place called The Tachman. Looks like he does great work also, including tach updates to three wire. Other than the techs though he is more about restoration where as rocketman is more about putting moder guts into factory gauges (which I am personally looking for).
For my 66 Chrysler 300, I would prob choose Tachman however.
Forum Test Account
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2014 at 2:53AM
Dave, I thought i remember someone sending their tach out to be updated?
The following thread is about a member who had his sport instrument cluster and gauges restored and repaired. This company had also repaired and recalibrated his tachometer. This company also advertises that they can convert a factory original type of tachometer into an electronic tachometer conversion.
I am not sure if this is the same exact member that you are referring to (that had his tach upgraded). The following link will take you to page five of his build thread. You can scroll down to the sixth post (down from the top of the page) on page five, to see where he wrote about this company that did the work for him.
I have never had any work done by this particular company to be able to tell you about the quality of their services and/or their prices. But you can probably ask the member who had the work done by them.
Click Here to see his build thread.
Click Here to see the company who did the work for him.
Click Here to send a private message to the member who had his tachometer repaired and recalibrated by the company in the Link above.
Edited by dave302 - 03-August-2014 at 4:13AM
Torinogts73c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2014 at 3:56AM
I find that interesting as I have had 3 different dizzys in my car. One was a single wire Mallory HEI with the GM style cap, 2nd one was a Unilite that I used with an MSD blaster coil, 3rd is Ford Duraspark with a MSD duraspark style blaster coil. Every single one I never had a tach problem at all! My car as you know is a 73 with factory Rallye gauge cluster. Now I have nere used the MSD 6AL box but I don't think that would make any difference as they have a plug and play adapter harness.
BackInBlack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 10:29AM
Are newer tach typically voltage driven now?
Are these new tachometer repairs/conversions voltage driven as well?
http://www.tachman.com/index.htm
Who is the other guy Paul recommended for Cougar, Mustang, Ford tachometer conversions?
I can't seem to find it now...
Reason I ask; I was about to buy the MSD tach adapter but realized that I probably wont need it if I get my tachometer converted/fixed by tachman.com
My tach is bouncing and jumping around.  Needs to be fixed/replaced.  I've been looking for 7k/8k options without any luck so I'm now looking at simply getting it upgraded by tachman.
Edited by BackInBlack - 13-June-2017 at 10:41AM
-John
1973 GTS
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 10:46AM
http://rccinnovations.com/
Rocketman's Classic Cougar Conversions
Seemed like a great option. I still need to get my tach done.
Some text from his website, and why I am so interested to use him:
" Although best known for my patent pending 'Rocketman Tachs', I also convert Ammeters to Voltmeters, produce overlays for the first generation XR7s and plug and play headlight relay kits that fit most 60's and 70's Ford products as well as Cougars. I can also recalibrate your Temp, Oil and Fuel gauges. Many of my products are sold by West Coast Classic Cougar, Mustangs Unlimited and National Parts Depot.
   Before we go any further, let me say that I do not do tachometer or ammeter repair, nor do I calibrate speedometers. I am not a rebuilder. There are shops that specialize in concourse restoration, rebuilding and repairing OEM gauges. I am not one of them. I upgrade existing devices or create new ones to meet modern needs.
   What I do is convert your factory tachometer from a 'two-wire' to an aftermarket '3-wire' tachometer. This is no conversion of the 40 year old movement - I replace the old movement and circuitry with brand new state of the art movements - the same ones used by many aftermarket gauges. My movements are custom made in the USA by an OEM supplier and have been engineered to dampen much of the needle bounce seen on tachometers installed in older vehicles or vehicles with 'lopey' cams . The biggest reason people ask me to convert their tach is so that they can get rid of the MSD adapter box. That's right, my tachs plug directly into the tach port of your MSD box or to the distributor side of the coil for points and Pertronix type ignitions."
Edited by GranTorinoSport - 13-June-2017 at 10:48AM
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 12:23PM
Thanks...that answers my question!
Fix the source of the problem...the tach.    I spent many hours searching for 7k/8k alternatives for our tach without any luck.
Oh well...guess I'll have to bump off the rev limiter...lol
-John
1973 GTS
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 1:49PM
He offers exactly what I'm looking for which is a stock look but modern guts and functionality. I'm not necessarily going for a complete original look but I haven't seen an alternate gauge install that has really reeled me in to date. I love Autometer stuff and have one in my 75 (trans temp) but I wouldn't want them for my main cluster.
Just personal preference of course.
Webmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 2:30PM
John,
I just had my tach done by Rocketman this spring.  He did an awesome job.   The tach is smoother than ever and seems to be more accurate (based on what RPM should be by calculations).  I was in the same dilemma, trying to figure out how to get a current sensing tach to work with something other than a stock ignition.  Like you said, it's easier to fix the tach, than make an old tach work with a new ignition.  Plus, now if the tach fails, at least your car will still run.
He probably can do an 8000 RPM conversion, but you'd probably have to supply the face plate.  He doesn't seem to stock any parts for anything that's not a Mustang or Cougar.  Keep your original tach pigtail and use that to make a jumper for your original harness.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 3:47PM
Tach is my next problem to solve...
Has anyone tried these guys?
http://redlinegaugeworks.com
They did a 7k tach for the pure vision torino.
Good to get feedback on rocket man tach...definitely will call him tomorrow
Edit: He said he can do 7k/8k but you have to provide the face or tach with the face.   So basically no dice.  None out there that look like OEM thats is 7k+.
Edited by BackInBlack - 14-June-2017 at 2:11AM
-John
1973 GTS
