i6 to 351w swap |
Author | ||||||||||||||
Grantorinosport351
Posted: 20-November-2014 at 2:56AM |
hey guys, i am hoping to buy a bronco for a mud toy for rednecks with paychecks....and the one im interested in has a 300i6 5 speed manual tranny 4x4.....if i got it, i would want to swap to a 351w...what would i need? is it just a clean out n' in swap? obviously motor mounts and maybe tranny mounts might be different....but what would i have to change on the motor? fly wheel? im not that experienced in this type of swap. probably not the place to post about a bronco, but i thought you guys could help. thanks.
~Bryan
Grantorinosport351
i read that it with bolt up, like the belhousing pattern is the same.
~Bryan
Bell is the same. Flywheels are not (but they WILL bolt on) 351 is 28 oz. external balance, 300 is internally balanced. 351 also uses a flywheel with a 11' clutch as opposed to a 10 or 10.5 for the 300.
Tranny mount doesn't change if you use the same trans, motor mounts will have to change, and I think that the mount perches are different... front accessories are going to need work, new brackets at minimum. All that aside, these are easy trucks to work on, and parts interchange with F150 for the same era. Have fun!
Grantorinosport351
so what do i need here? balanced flywheel and 11' clutch?
~Bryan
Best bet is a clutch kit (flywheel, disc, pressure plate, throwout bearing, pilot bearing) for a 351 with that trans
Grantorinosport351
thanks!
~Bryan
n2fordwagons
Just throwing this out there. Why not get one that already has a 351W? They are in abundance out there.
If you're still gonna pursue it, find a F150 or Bronco with 351W that you can pull and use. It will have everything you need to transplant. Edited by n2fordwagons - 21-November-2014 at 12:48AM |
Jeff
Grantorinosport351
i want this one because it has a 6 inch lift, 35in superswampers, another new set of mud grips, alot of new parts, a fastback rag top for the back (plus hard shell), and it runs and drives....800 bucks!.....i wont know until like a week before i could get it.....and if i can find a parts one with a 351, i would use it....but i was told the 300 i6 has more torque than a 302? so i might leave it in for a while until i can find a 351, or just wait til i find a parts one with a manual tranny.
~Bryan
n2fordwagons
Ah. I see. That sounds like a great deal. Yes, the 300 I6 is a workhorse. If it's running good, there's no immediate need to replace it.
I'd love to get a ragtop for our Bronco. We've got a '96 with a 351W.
Jeff
You'll love that 300. Great engines that will always run if they have water, fuel, spark and oil.
Grantorinosport351
awesome! im wanting to buy it for offroad events and such...i think i might keep the i6 for a while, put in a hei dist, maybe a new carb. but eventually, i will want a 351.....hopefully i get it. ill post pics if i do!
Edited by Grantorinosport351 - 21-November-2014 at 4:28AM |
~Bryan
Grantorinosport351
do they make performance parts for the 300?
~Bryan
Depends... What year.
300 is a very durable engine with a LOT of low end toruqe
dave302
FORD 300 6=8 Cast Aluminum "STREET & s\Strip" Intake Manifold Price: $319.00 Shipping Weight: 18.00 pounds Code: 43-4502 With your choice of: 2 Brl Carb Adaptor 4 Brl Carb Adaptor Redline TBI Adaptor Howell TBI Adaptor Fittment: All Ford 240/300 cid. Description: Our Ram Flow Manifold is a single 2 or 4 brl. carb design, making it Clifford's most versatile manifold. It has an open plenum, allowing the user to mate a 2 barrel, 4 barrel or fuel injection system by changing carb adaptor. Weber 38/38 use 08-1013 Holley 390/or 500 Edelbrock carb , use 08-1014. Click on the adaptor of choice when ordering online. This manifold is made of cast aluminum and is a street or competition style for performance. The true beauty of this manifold is that it works exceptionally well on the street, thanks to our water heated passage along the bottom of the manifold. No matter where in the world the user is located, the water heated passage is a must for daily street use. By using a water/coolant mix to heat the manifold, we can atomize the fuel without boiling it, creating a consistant running engine. This manifold requires a minimum of 350 cfm, and will not bolt onto your engine with the factory cast iron exhaust manifolds. Please do not plug the water jackets and start your engine. Aluminum melts at 450 degree's. *Do not bolt any stock carb to this intake. It has oversized runners and will need an upgraded 2 or 4 brl carb. Edited by dave302 - 21-November-2014 at 2:09PM |
dave302
Edited by dave302 - 21-November-2014 at 12:23PM |
dave302
Edited by dave302 - 21-November-2014 at 12:25PM |
dave302
dave302
63-0144 FORD 240-300/4.9 Header/Intake GasketPrice: $20.00Shipping Weight: 3.00 pounds.
Fittment: All Ford 240/300 cid. Description: Gasket designed specifically for use with headers. This has all the intake and exhaust port on one gasket and is made 1/8" thick to ensure a great seal. Edited by dave302 - 21-November-2014 at 12:50PM |
dave302
43-4176 FORD 300 "VALVE COVER" CAST ALUMINUM Code: 43-4176 6=8 Cast Aluminum Valve Covers: Made to complete your engine upgrades with great looks and reliability. Kit includes Valve Cover, Gasket, Glue, Air Breather, grommet, black oil cap& instructions. It also has room for roller rockers. Will not fit with EFI system. Carb only please. Edited by dave302 - 21-November-2014 at 12:32PM |
dave302
Ford 240/300 Combination! Header/Intake/Weber Carb Kit Code: FordCombo The 6=8 Kit includes: 6=8 Dual Truck Headers/Header Gasket/Street Hookup Kit. 53-0960 Header Stud Kit 6=8 High Flow Intake Manifold W/Water Jacket 43-4502WH Redline Weber 38/38 DGAS (2) Barrel Carb W/Electric Choke 08-7038- Air Cleaner, Linkage kit, Fuel Regulator, 6=8 Adaptor, Gaskets/Nuts/Bolts. Your new Weber carb is set up from our warehouse and ready to bolt on and go. Edited by dave302 - 21-November-2014 at 12:33PM |
dave302
32/36 DGEV Twin Weber System Code: 3DTWS 6=8 Ford 240/300 32/36 DGEV Twin Weber System includes: 6=8 Dual Carb Intake Manifold W/Water jackets. *This is the first of it's kind available for your Big Ford. (2) 08-1013 Weber Carb Adaptors (2) 08-7033 Weber DGEV Progressive Carbs (2) Redline Air Cleaners (1) Dual Regulator Your new system will be set up with linkage and ready to bolt on, out of the box. Edited by dave302 - 21-November-2014 at 12:37PM |
dave302
Ford 240/300 6=8 Combination Code: F The 6=8 Kit includes: 6=8 Dual Shorty Truck Headers/Header Gasket/Street Hookup Kit. Header Stud Kit 6=8 High Flow Intake Manifold W/Water Jacket 43-4502WH Redline Weber 38/38 DGAS (2) Barrel Carb W/Electric Choke 08-7038-K, Air Cleaner, Linkage kit, Fuel Regulator, 6=8 Adaptor, Gaskets/Nuts/Bolts. Your new Weber carb is set up from our warehouse and ready to bolt on and go Edited by dave302 - 21-November-2014 at 12:36PM |
dave302
To see the company that sells all of these parts and more Click Here.
Edited by dave302 - 21-November-2014 at 12:47PM |
dave302
To see another company that sells performance engine parts for the 300 engine Click Here. Some of ther parts for sale are listed below. Product ID: DUI-300-CIK DUI Complete Ignition Kit - Big Six Details: Save $10 by ordering the complete DUI Ignition Kit, which includes the DUI Distributor, Custom LiveWire set, and Billet Wire Looms. Please designate the cap color and wire color when ordering. see DETAILS for more information. NOTE: We highly recommend reading our Tech Article on "Preventing Premature Distributor Gear Failures" before you install your new distributor.
Black, Blue or Red Wire Color: Black, Blue, Red or Yellow Loom Color: Natural or Black Anodized (+$7.00) DUI-300-CIK -------------------------------------------------------------------------------- Product ID: DUI-300-DZY DUI Performance Distributor - Big Six Details Manufactured by Performance Distributors, the DUI dizzy is the only one-piece, high performance ignition system available for your inline six. Requiring only one 12V hot wire for hookup, it is a clean and simple (drop in) performance modification. See DETAILS for more information. NOTE: We highly recommend reading our Tech Article on "Preventing Premature Distributor Gear Failures" before you install your new distributor. Cap Color: Black, Blue or Red DUI-300-DZY ------------------------------------------------------------------------------------------------------------------- Product ID: FSP-300-EFK Stainless Steel Bolt Kit Details This 167 Piece - 6 Point Hex Head Bolt Kit is available un-polished or polished (extra), and fits Ford 240/300ci engines. See Details for more information. NOTE: Always use an anti-sieze lubricant when you install stainless steel bolts or studs. Kit includes one 10 oz tube. Finish: Un-polished or Polished (+$30.00) Edited by dave302 - 21-November-2014 at 3:42PM |
Senior Member Joined: 30-July-2010 Location: On The Road Status: Offline Points: 6070 |
back in the day they used to cut a cylinder off each Cleveland head & weld them back together as a 6-pop
there's a kinda weird 'underground' for aftermarket high perf 4 & 6 parts, heads, blocks, not sure what's out there for the Ford 300? but it's not from the usual sources, definitely off the beaten path
Edited by Rockatansky - 21-November-2014 at 1:43PM |
i used to have that clifford manifold, sold it at a swap meet for $40
Grantorinosport351
thanks alot guys!!.....btw its an 82 bronco, and im pretty sure its the original engine.
~Bryan
dave302
Edited by dave302 - 21-November-2014 at 3:08PM |
