tko 500 |
jadeezra
Member Joined: 15-February-2013 Location: Indiana Status: Offline Points: 89 |
Posted: 30-January-2015 at 9:39PM |
Okay ran across a smoking deal on a tko who's done tgis in a 72-76 torino? What does it entail
start with basics clutch pedals linkage bell housing.
What motor? Flywheel, exhaust headers that fit. Driveshaft is ok to reuse assuming you have a factory four speed. Clutch kit, etc. |
Pondering: #99Problems |
jadeezra
400 I have a feeling it may be a pain in da butt
Edited by jadeezra - 01-February-2015 at 5:25PM |
It can be done but you need to know what engine that transmission was set up for originally.
In the case of the 400 you need to source a flywheel the engine block off plate that goes between the engine and behind the flywheel. Installs before you bolt on the flywheel. Fordmuscle.com had started a series on installing a t5 behind a 400 but it was never completed but there are good reference details that can help. As other guys have said you can adapt late model mustang clutch pedals to work with the stock hanger. It's just that you need to be able to fabricate it's not a bolt in procedure. |
BadHabit351
Senior Member Joined: 21-June-2013 Location: United States Status: Offline Points: 217 |
Should you decide to abandon the idea, give me a price on the tranny.
1973/72 Gran Torino Sport
1971 Torino GT convertilble 2013 Ford Fusion 2004 Ford SuperDuty 2013 Mustang GT |
Also keep in mind on the tko if a Cleveland you need to swap input shafts to a short shaft.
Myself because how I drive I'd spend the money for the pads on the forks to be changed out from stock material. If you drive like a grandma stock is fine...but if it was like my family were shifting a 5k lol Psquare75 had great luck with a tko for his 429 in his f series. The shop was good the guy knows his Ford stuff. |
madmaxtorino
I have the block plate, bellhousing, and adapter to fit tko on a 400. that i wont be using.
Allan
