429 Swap Into 73 Torino |
Chrisu92
New Member Joined: 09-June-2015 Location: Abilene, TX Status: Offline Points: 3 |
Posted: 09-June-2015 at 3:12PM |
I have been trying to get my 429 into my torino but i have been having problems getting the correct motor mounts. Do you guys recommend any sites i should check out so i can drop this motor into the car? I have herd good and bad about crites and can not seem to find any private sellers at the moment. Thank you for all the help.
1973 Ford Gran Torino
Nuggets
You can buy the cradle style mount from summit, that would probably work quite well or just make custom sheet metal mounts in a pinch
Tinman fabrication mounts are excellent too if you don't mind welding to the chassis |
Barnaby
Regul8r
Crites is the ONLY one who makes these mounts right now.
Big Block people have NO CHOICE right now unless you find some take-offs or NOS somewhere. |
Chrisu92
Have you used these mounts before? I just want to make sure they work before I buy them.
Nuggets
http://www.summitracing.com/parts/trd-9313/overview/year/1973/make/ford/model/gran-torino
http://www.tinmanfabrication.com/index.cfm/page/ptype=product/product_id=90/category_id=88/mode=prod/prd90.htm These were the ones I was talking about, bit more fabrication but having used the tinman 440 mounts they are beautifully made and fitted perfectly. Come with new hardware too so all you need to do is weld the tabs to the chassis somewhere |
Barnaby
Chrisu92
Okay yeah. I have seen those. My only problem would be the welding. I was just trying to look for some stock ones. But I might check those out.
Regul8r
Crites are the ones that everyone here with the 429/460 use.
They are direct bolt in. |
The Crites mounts work well if you can't find NOS. They are not an EXACT copy but they do a good job. There are other ways to do the job, but the Crites mounts are a bolt-in, no-fuss way to do the job.
Billy C
Just out of curiosity what is the difference between the stock and crites mounts as far as motor placement goes?
i'm assuming the stock 460 mounts are just like the factory v-8 monza mounts...parts stores look at you like your stupid because they aren't available anymore??? or am i just missing something here?
From what I have heard and/or read, the Crites mounts are a bit shorter than the factory motor mounts, this causes the engine/headers/accessories to be placed closer to the chassis and in some cases cause interference. It seems they are lower about 3/8"(give or take 1/8"), not entirely sure. If you want to use Hooker 6126 headers(or possibly factory exhaust manifolds), try to find factory mounts or you can add a 3/8" plate to the Crites mounts where it attaches to the engine block to get the engine placed correctly for sufficient clearances. Here is a link to a person using Crites mounts in a '73, hope this info helps. Good luck, Todd
Dan the ranchero man
The engine mounts from the 72-76 Ford t-birds (all big block cars) will be the correct engine mounts for your project. (same engine cradle as torino) I have used them on both of my rancheros 74-79 and they bolt right up. Also the 72-76 torino (2,4 DR and wagon),74-76 cougar/elite, 72-76 montego (2,4 DR and wagon are all cars that if set up with the 429.460 will have the correct engine mounts.
Tim1859
Member Joined: 29-December-2006 Location: West Michigan Status: Offline Points: 75 |
And 72-76 Lincoln Mark IV
Former owner of '73 GTS and current wannabe
Carl
Member Joined: 21-March-2010 Location: Colorado Spring Status: Offline Points: 191 |
Rock Auto has them for ~$15/ea.
Easier to use the Crites mounts.
carguy47
Senior Member Joined: 08-October-2011 Location: Phoenix, AZ Status: Offline Points: 373 |
I put a 429 into my car without buying any aftermarket mounts. As one of the other members stated, you can find stock BBF mounts on eBay, Rock auto, Autozone and Checker.
Billy C
The ones at the auto parts stores including RockAuto are wrong last time I checked. They are actually for Ford full size cars.
