Spacer Plate GRAN TORINO 73 |
jessie
Member Joined: 13-February-2015 Location: PARIS FRANCE Status: Offline Points: 44 |
Posted: 09-July-2015 at 10:58AM |
Hi,
I'm from France (Paris) I've bought a very nice 73 Gran Torino Fastback 351 Cleveland 2bbl, almost a year ago. I need to replace my spacer plate, it's very used, tried ebay and rockauto but nothing...Impossible to find one for the moment, any suggestions please ? Thanks in advance. |
are you referring to the one under the carb?
welcome! post some pics of your car when you can |
yes they are getting hard to find http://www.ebay.com/itm/Ford-truck-2-barrel-egr-valve-and-spacer-plate-/191623537056?hash=item2c9da721a0&vxp=mtrand be aware that the gaskets involved are somewhat special, they need to hold up to exhaust temps this kit STANDARD MOTOR PRODUCTS Part # VG202 is available from www.rockauto.com is it possible that your problem is just the gaskets?
jessie
Yes the one under the carburetor
jessie
jessie
Thanks for the links Rockatansky, but is it gonna fit for my 73 Torino (351 5,8 Cleveland 2bbl) ?
Not the gasket for sure, have a look : |
that's what they do, either clog with carbon or erode & burn through... that one you have there will never hold a gasket for very long
as far as fitment you'll have t match up the pics as best you can, or try to go by the numbers. sometimes there are multiple part numbers that are basically the same & will work, or the same part but a different year thus a different number this new plate just showed up, looks like it should work for you? the vacuum nozzle sticking out can just be blocked off with a rubber cap & hose clamp if you have no use for it, if it's even machined open? it looks like the one I linked above but the hose connector is not present so it may be solid / not machined here is one with the nozzle and the hose connection Edited by Rockatansky - 12-July-2015 at 2:43PM |
here's one that matches more closely to yours but may not ship worldwide
nice car! looks to be in near perfect condition
Nuggets
I might have a 2bbl spacer plate at home......cant remember if I sold it with the carb or not, will check on wednesday when I'm back
Barnaby
jessie
Nice ! Thanks Nuggets !!
5,8L 351 Ceveland (73 Gran Torino) Let me know ! |
jessie
Thanks CaliforniaJohnny !
Yes it is, saw it on ebay 2 years ago, I've missed it, but the car was sold in France !! So I asked to the new owner if he wanted to sell it, and now it's mine ! The interior is near mint condition, never replaced, it's impressive. |
albo74
Senior Member Joined: 25-February-2006 Location: ME. USA Status: Offline Points: 616 |
OK so what I did was plane down the spacer plate to get a nice smooth surface , then tap the exhaust ports on the spacer and plug them off , lock tight , forget recycling emissions gasses , then use a gasket that was used prior to 72 , hooked every thing up to look stock , but no more of that dumping un burned fuel and exhaust gasses into the top of that engine . runs great .
albos73gts
^^^ i was going to suggest that. plugging off that emissions crap, that's what i do on all my cars. that egr plate was a stupid design IMO (just for this reason!)
jessie
Thanks Albo for your answer,
My english is not so good, so what do you mean excatly "tap the exhaust ports on the spacer" ? And how do I plug them off ? With some material ? I don't get it, sorry for this language barrier... |
Tapping means to cut threads into the hole so you can install a pipe plug.
Your EGR spacer has the part off the back for the backpressure transducer. Those parts usually rotted apart inside of five years. If you don't have emissions testing, get a solid spacer.
Montego
New Member Joined: 18-January-2011 Location: Fremont, NH Status: Offline Points: 30 |
Jessie has my old car over in France.. I've found him the correct spacer for the 73/74 351C / 400
He also needs the flex hose that attaches to the end of the snorkel on the air cleaner.. It was there when I sent the car overseas, but its gone now. He doesn't need the plastic at the other end.. just the flex hose itself.. Anyone have one in good enough shape to use? Here's the car in Nov 2013 a few weeks prior to departing the USA.. Edited by Montego - 16-July-2015 at 12:50AM |
gpd294
Senior Member Joined: 18-September-2008 Location: Dallas, Texas Status: Offline Points: 2181 |
Not to be negative Nancy here, but I had a hard time finding one of these. Luckily I ran across one on Ebay fairly cheap. I'm not sure why the Autopart stores just don't carry them anymore.
Nuggets
Had a look, unfortunately its gone. Only thing I've got left is the manifold and no one wants them
Barnaby
^^^that bronco one should fit? says 66-77 i think most of the cars were the same in the 70's IIRC
jessie
Thanks for your help Big Bird !!!
jessie
Hey Montego !!!
Thanks helping me !!! The car's still the same, amazing ! I'll send some pics with the Eiffel Tower in the background as soon as everything is fixed !!! Can't wait to drive this awesome car, she's sleeping in the garage... |
jessie
Hi Nuggets,
Thanks for looking ! |
jessie
Hi Rockatansky,
Looks the same, just need to know if it's the right size...I've tried to find some infos, but nothing about the size. Thanks. |
I checked on the Autozone page, 1975 Torino uses the same part as 1975 Bronco
I also came up with Dorman 96052 but that number is a dead end, these fresh air tubes may be going extinct This product is a fit for your: Part Number: 96052 Alternate Part Number: P2516-25 This product is a fit for your: Part Number: 96052 Alternate Part Number: P2516-25 Edited by Rockatansky - 17-July-2015 at 3:30AM |
